cb radio power
Old 10-13-2008, 07:20 PM
DupermanDave's Avatar
cb radio power
I got my (dead) grandpa's old CB radio. I'm wanting to install it into my 89 toyota pickup. I looked under the dash/cigarette lighter/ash tray area and found a bundle of wires. Red, black, yellow, green...which two are powered that I can split off to power the CB radio? Do I need to go in with a multimeter or can someone point out the right colored ones?
Old 10-13-2008, 07:22 PM
just a 22re's Avatar
well red mostly hot yellow is mostly switched black is mostly ground and green sounds like a light id say try that WITH a tester to make sure as i dont know what wires your talking about just test them and see what does what and when
Old 10-13-2008, 07:28 PM
pff. It never occured to me to even wire it directly into the fuse box. Could I wire it to some 30 amp fuses under the dash? The previous owner has the fog lights wired this way, with a switch under the dash to enable/disable them. Could I do the CB the same way?
Old 10-13-2008, 07:33 PM
1989toy4wd's Avatar
You can, but the radio should already have a inline-fuse but if not add one I would do 15amp though maybe even 10 CBs dont create that much amperage, In the chevy I just wired it directly to an unused spot in the fuse box, works great and turns off when key is removed!!!
jasonty
41
12-23-2018 01:00 PM
mussy01
12-13-2016 08:20 PM
theking11863
03-19-2016 09:36 PM
Team420
12-30-2015 01:31 PM
Mrhoadley
08-04-2015 06:08 PM
Quick Reply: cb radio power
