cant get head gasket to seal at timing chain cover
I am having troubl getting my head gasket to seal between head and timing chain cover on a 86 22re,is there any tips for this procedure,i mean should i use any other kind of sealer along with the gasket? it doesnt leak oil on the corners but on the front on both sides of the penninsula and pooling on top of the water pump. Any ideas would be helpful as I am new to major repairs on engines.
pull the head
I am going to pull the head(for the second time)but I want to make sure it gets done right this time so what do you think? Any preference on brand of gasket? Where and how much sillycone to use?Any thing you learned when you did yours that would be helpful?
Get yourself an fsm! Google "ttora fsm" that will help, they have one for an 88 that will work. It details the tear down and re installation including where to place sealant. Toyota oem gaskets are widely recognized as the best quality hg.
before pulling the head, try this, loosen all the bolts that go through the timing cover that run into the block, don't remove them, and then tighten down a little more on the bolt on the top of the cover that is in the head and under the cam. However don't too too tight with it either as it's a small bolt and can snap pretty easily. If that bolt isn't tightened before the rest of the cover mounting bolts it might not seal tightly.
Of course this is all assuming the timing cover was done with removing the head in the first place and the head gasket was not pinched when installing the cover with the head still on.
IMO Toyota brand FIPG or ultra black RTV would be the best to use.
I remember when I did the timing chain on my rig, putting the cover back on without taking off the head I messed up the head gasket...which led to a head job then. It was hard to squeeze it between the oil pan and head. Maybe you might have damaged it?
While you're doing that, use some high grit sandpaper, and a razor, and take down any old gasket on the head and block.
Then install the tchain cover.. then put a dab of rtv on the corner where the block and tchain cover meets. (Really not necessary)
At this point make sure you leave the bolt for the alternator tensioner out. Or install it..
Set down headgasket and go from there. I used fel pro and rtv on everything, and no leaks yet
thanks fellas
ok thanks,i think im going to try xtreme's idea first,and yes I pulled the head to install the timing cover the first time so the head gasket should be intact,also the head has been resurfaced.I dont think there is a contamination,but hard to be positive.(as in non removed rtv or gasket material on the block or timing cover). Now does anyone know the proper torque for the head to timing chain cover bolt, its like a 10 mm or something. Also if this fails then what do you think would be my best course of action(pull the head obviously) but any tips would be appreciated. I think I would elect for oem gaskeys from here out.
torque
thanks,i will check back in when i find out how much torque it takes to snap off that 10mm bolt that goes through the head and the timing chain cover.
right
upon further inspection I found a hairline crack in the timing chain cover underneath where the bolt goes in from the head,I think the gasket was ok so it should be fun from here.
The fix - JB Weld
1 year and no leak...
all messed up
hey im new to yotatech and not that good at puters,i cant remember how to start a thread.can you help? I want to know if yall know of a good write up on pulling the tc cover without removing the head. thanks,sorry for my dumbassness.
Click here. Its the one I used. I put no responsibility of my above problem/mistake on the instructions...
This has been covered many times. I have not been around long enough to chew you out for not searching first, so I will defer that to others.
I get it, Iam new to the forum AND computers but I am learning them as I am also learning toy repair(I dont know which is harder yet) I look forward to giving back when I get the hang of it.
