Can't get freon to go in
Old 06-13-2007, 09:15 AM
Lifelongtoy's Avatar
Question Can't get freon to go in
If the compressor is working, the system is completely clean, and there are no clogges or leaks, then why wouldn't 134 go in.
This is my final problem for my A/C. I'm counting on you guys to save the day once again.
Old 06-13-2007, 09:19 AM
Intrepid's Avatar
You have to have the vehicle running with the AC running on high and put the refill into the low pressure side IIRC. Only thing I can think of otherwise is, is the hose or whatever you are using working right?
Old 06-13-2007, 09:22 AM
It might be the hose, didn't think about that. But ya, got the A/C is on high on the low side.
I was thinking that it might be something with the pressure switch. Maybe somehow it is not functioning
Old 06-13-2007, 10:51 AM
jjrgr21's Avatar
is it an old can? i had the same problem, went and bought a new can and presto
Old 06-13-2007, 12:01 PM
Intrepid's Avatar
I don't know what you are using, but did you puncture the top on the recharge can?
Old 06-13-2007, 12:46 PM
ChickenLover's Avatar
Sometimes it takes a couple minutes for those cans to empty themselves. Hold it upside down, and every 5 seconds turn it on its side then back.
Old 06-13-2007, 01:31 PM
shiftless89's Avatar
did you remove the old valve core before you put the 134 adaptor on? and are you sure you are putting it in the low side?
Old 06-13-2007, 01:38 PM
THAT OLD CORE HAS TO COME OUT!!!! Ohhh man. So if the core is still in after screwing the new adapter on, nothing will go in?
but yea its on the low side.
Old 06-13-2007, 01:40 PM
harpen123's Avatar
turn it upside down or put the can in warm water. also you can feel the can gets light when its empty.
Old 06-14-2007, 10:44 AM
i hope thats sarcasm. but if not, yes you must remove the old cores before the adpater is screwed on
nanhodges2733
05-29-2020 03:28 PM
DiggnDeep
09-03-2015 02:45 PM
klavender1
08-15-2015 01:51 PM
stock87yota
07-31-2015 10:08 AM
vegascoug
08-18-2007 10:49 AM
Quick Reply: Can't get freon to go in
