Cant find ISR mod parts...
Old 11-23-2008, 12:38 PM
Tubbyfatty's Avatar
Ive been looking around at lowes and home depot and all i found were hose clamps and ducting.
Where did you guys get your parts for this mod from?
I know there are many threads abotu this mod but im trying to find stores that carry the parts.
Old 11-23-2008, 12:51 PM
Tubbyfatty's Avatar
Im looking for these parts.
5" of rubber hose 3" inside diameter
1-90 degree 1/2" brass fitting , 2 washers and 1 O-ring to fit this fitting
(one end has to push a hose on the other has to have threads)
1-90 degree 7/16" brass fitting , 2 washers and 1 O-ring to fit fitting
1 nut to fit the 1/2 fitting
1 nut to fit the 7/16 fitting
Old 11-23-2008, 01:42 PM
89needsatranny's Avatar
I'm having the same exact problem. i went to HD and only found the 1/2" el fitting with one barbed end and the other threaded but the threaded end was 3/4" and i thought it was going to be too big to thread into the 3" pipe.
I couldn't find a 7/16 at all but i was thinking 3/8 might fit since that would be 6/16" (just 1/16" off). anyone disagree? can we just clamp the hose onto the fitting if its too loose?
and about the hose... your auto part store should sell silicon hose in the cold air intake section(plus it comes in blue, red....)
the washers and nuts should be easy to find.
Old 11-23-2008, 01:49 PM
toyotanick's Avatar
whats ISR?
Old 11-23-2008, 01:51 PM
Squeebs's Avatar
Originally Posted by toyotanick
whats ISR?
intake silencer removal
Old 11-23-2008, 01:56 PM
toyotanick's Avatar
alright. and what is the advantages of this being removed?
Old 11-23-2008, 01:59 PM
Tubbyfatty's Avatar
89needsatranny, I couldnt even find the elbows....
And i looks like in some of the pics that the hoses are hose clamped on to the fittings.
Heres a link, its amazing. Well according to pther people.
https://www.yotatech.com/~corey/tech/blu_intake/blu.htm
Old 11-23-2008, 02:00 PM
basically sound purposes
but the stock setup is pretty restrictive so this mod is supposed to free up the flow
alot of people say you can get a decent amount of torque for the price.
Old 11-23-2008, 02:02 PM
toyotanick's Avatar
hmm. o might give it a shot after ya'll seccesfully pull it off
Old 11-23-2008, 02:03 PM
tubbyfatty, you can Google barbed or brass fittings on Google and search around on plumber warehouses.... i did not think their prices were right. the half inch brass fitting i seen was like $15 or more
Old 11-23-2008, 02:05 PM
abecedarian's Avatar
may I suggest plastic fittings instead of brass? you can get nearly any size fitting and all you'd have to do is tap the pipe and thread the fitting(s) in. and if you're worried about sealing, a thin bead of sealant on the last few threads should seal it up.
and if you have an issue finding a 7/16 fitting, going up to 1/2 and using a 7/16 barb would be better than going down to 3/8 elle
Old 11-23-2008, 02:06 PM
Tubbyfatty's Avatar
Alright. Yea $15 for a fitting...
I need to find all the other stuff too, so I might just take a drive around where i live.
Old 11-23-2008, 02:07 PM
abecedarian, "tap the pipe and thread the fittings"? any more detail on that??
Old 11-23-2008, 02:09 PM
and maybe don't restrict yourself to brass: galvanized and cast iron fittings may be an option.
drill the hole in the pipe slightly smaller than you need and then use a 'tap' to cut threads the hole so the fitting screws in. that way you don't need a nut on the inside.
Old 11-23-2008, 02:10 PM
yeah, i know right?? this one is $11 but still....http://images.google.com/imgres?imgu...icial%26sa%3DG
Old 11-23-2008, 02:11 PM
Tubbyfatty's Avatar
I never thought of using anything else... I was just trying to copy the mod exactly. ha.
Old 11-23-2008, 02:16 PM
Tubbyfatty's Avatar
This guy is full of answers!
Old 11-23-2008, 02:17 PM
thanks i will look into other materials. is it possible to JBweld pvc to aluminum?? or at least use it as a sealant?
Old 11-23-2008, 02:18 PM
They don't always match the question though.
Quick Reply: Cant find ISR mod parts...
