can you fit 35s on a SASd OME 2"hd springs
I want to stay as low as possible... I'm ok trimming, I'm curious if anyone's done it before, and how much have you had to trim?
Steve Schaefer ( http://www.sonoransteel.com ) did it to a Tacoma I think....low profile.....spring under in the front SAS makes it possible.
Check out "sprung under runner" I'm still doing research and am wanting to do something similar: http://www.pirate4x4.com/forum/toyot...=1458258165370
Hey rustED,
That's a cool thread. thanks
http://www.pirate4x4.com/forum/toyot...er-runner.html
So many kits out there with rear thru the frame shackles and high steer......ZERO with front shackle and old school y-arm steering.......
Current Update:
35s under a 2" lift fit and tuck pretty well. I have some minor rubbing on a split splash guard. After cutting the bent part it should be fine. The only other modification was to the inner pinch seams.
