can someone verify this...
Old 01-27-2008, 10:22 AM
22REFORME's Avatar
This is a timing question on a 22RE.
with the valve cover off so u can watch the crank tdc mark and the cam tdc mark at the same time, do the two marks line up every rotation? if not how often do they line up?
Old 01-27-2008, 10:25 AM
jasond's Avatar
Every other, the crank spins twice as fast as the cam
Old 01-27-2008, 10:30 AM
22REFORME's Avatar
thank you, i knew this... i just wanted to make sure i wasn't crazy. and now i can verify that my truck is FUXD
Old 01-27-2008, 01:36 PM
Staff
DeathCougar's Avatar
crank to cam ratio is always 2:1 in any engine. Is yours not doing this?
Old 01-27-2008, 02:56 PM
Mister Willie's Avatar
I don't see how it could not be doing it, unless your timing chain is too long (84 or earlier chain on an 85 or newer engine) or it's skipping chain links a lot. In that case you'd have bent a valve or 8 by now, right?
Blamalam
03-12-2022 07:34 AM
I8URSVT
10-05-2015 05:42 PM
larrys93pickup
09-17-2015 07:05 PM
user 82300
09-17-2015 10:41 AM
anniesball
09-07-2015 11:20 AM
Quick Reply: can someone verify this...
