Can someone help me identify a 22re plug and parts
Old 07-17-2008, 02:12 PM
cunninglinguist's Avatar
I'm trying to get my AC going. I just got the retrofit today and it blows cold but my idle sucks. I noticed I don't have the idle up valve in my engine compartment so I stole one from another motor (which doesn't have AC).
My truck is an 86 pickup but I don't know if the engine is from the same truck because my truck has AC components but the idle valve was missing.
Could someone help me identify the plug that is in the red box?
Also, does anyone know how the 2 smaller hoses on the ac idle (thing in the green box) up is routed? There are 2 small ports (cant see in my pic - 1 on the bottom and 1 at the back ) that are plugged right now. I stole the picture below from pirate.
It looks like I have a different valve in the top right corner.
Also, what is the part in the purple box? The 2 ports are plugged?? Am I missing some stuff??
Thanks
Old 07-17-2008, 02:37 PM
bigt's Avatar
opps sorry i am of no use!
Old 07-17-2008, 03:32 PM
idanity's Avatar
if its anything like my truck, (barely any hoses left that are still plugged in) it wont matter.
but.
i would check w/the dealer, b/c they have the digital manuals and print pages up for me when i visit them and get oil filters.
plus, they can tell you how/what size the hoses that are needed.
i can only see the lower pix, and cannot see a green box, but will look when i get home (work i.t. dept is paranoid)...
hope that helps
Old 07-17-2008, 03:38 PM
InternetRoadkill's Avatar
Green box: A/C idle up valve.
Purple box: Manifold vacuum source.
Red Box: electrical plug to A/C idle up solenoid (???)
edit:
Oops, didn't read all of the OP. That looks right in second pic. The blue valve in the top pic is part of the EFI and emission control stuff.
I think I got it now from Roger Brown's site:
That guy is a godsend.
Looks like I'm missing the thingamajig in the bottom right corner.
Old 07-17-2008, 03:49 PM
abecedarian's Avatar
I hate it when I can't find my thingamajig.
Sometimes I have to borrow other people's whatchamacallits, but it's not the same.
good luck
Old 07-17-2008, 03:54 PM
Targetnut's Avatar
That would be the A/C idle up solenoid
note the way the hoses are routed in that picture, It is the correct way.
Once you have that hooked up you should be able to adjust the A/C idle with the big black screw on top of the A/C idle up valve. and that should be about 50rpm above regular idle
Old 07-17-2008, 03:59 PM
HelliphinoN8's Avatar
I thought the idle up thing was behind the glove compartment...? Cunninglinguist..lol, how's the a/c do with 134A in it?? Does it still blow cold when yer stopped at idle? I'm thinking about retrofitting mine as well, as it leaks out the Freeze-12 every 3 mos. and it's getting expensive. Plus the summers here in AZ last basically 6 MONTHS and are hot as hell.
Old 07-17-2008, 04:10 PM
Targetnut's Avatar
The "thing" behind the glovebox is the A/C amplifier (controller). It is what controls the operation of the compressor and the idle up solenoid. The adjustment is to control what minimum RPM the A/C will shut off.
Old 07-17-2008, 04:12 PM
Well, I just got the thing converted this morning and it was never working before this. It does blow cold at idle but more so when it's going. It's hard for me to rate it just yet. LOL, this is the first vehicle I've ever had with a functioning ac so right now I'm quite giddy. It may wear off after a while when I start to compare to other vehicles.
I live in Vancouver Canada. It doesn't get quite as hot as where you are and I probably only need the cold for about 3 months of the year. The rest of the year I'm only gonna use it to defrost my windshield. The guy who did it for me was my old neighbor who is an ac mechanic and he said he will take care of me if it leaks away or it's not cold enough next time.
06-01-2021 01:51 PM
toyota32
07-06-2015 05:42 PM
elwood73
07-05-2015 07:07 AM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Can someone help me identify a 22re plug and parts
