Can I use Bosch R3 Platinum R2 spark plugs in my 91 4Runner???
need to know if its okay to put these spark plugs in my 91 4Runner.
get back to me with any info you have please
spark plug specifics:
(Bosch r3 Platinum r2 / splitfire)
Umm yes, but I sure would not!
The best plug to run in any vehicle is the plug the factory put in it.
ETA: I am sure someone is going to complain and say they use Plutonium, laser, quad fire, plugs and they work fine. Many time the an engine is designed around a particular spark plug. Or hundreds of hours go into finding a plug that will produce the most efficient burn in a particular combustion chamber.
There is no point in reinventing the wheel, a basic Nippon Denso, or NGK plug that it calls for will run better than any expensive plug you can find, and they are cheaper.
Um, both are copper core plugs.
Taken from NGK site: http://www.ngk.com/product.aspx?zpid=9325
"Most spark plugs contain a copper core for increased conductivity, improved heat control and improved resistance to fouling."
psill68
12-15-2013 08:36 AM
Gregg
04-16-2006 06:52 PM
DavidA
10
12-01-2005 08:56 PM
Jagin
14
01-23-2005 02:28 PM
ravencr
9
01-16-2003 07:27 AM
