Can I add tranny fluid through shifter hole?
Old 03-27-2007, 08:15 AM
Frank's Avatar
The title says it all: the W55 is out of my '94 pickup which means the shifter hole will be easily accessible once the tranny is back in. Can I just add fluid through this instead of fooling with the fill plug on the side?
TIA
Old 03-27-2007, 08:28 AM
Ringmaster's Avatar
Yes you can.
Old 03-27-2007, 08:33 AM
Tdubbs05's Avatar
if it's the r150 tranny (tranny for the 3.0) then i think you're supposed to add fluid through the dipstick. that's what i did when i did my tranny flush.
Old 03-27-2007, 08:57 AM
MMA_Alex's Avatar
manual trans = yes. Just make sure you check how full it is at the fill hole underneath the truck.
Old 03-28-2007, 11:18 AM
Frank's Avatar
Thanks - the W55 is the 5-speed behind the 22RE; it'll be a lot easier pouring from the top!
jasonty
41
12-23-2018 01:00 PM
Tonetrk
08-06-2015 10:06 AM
TDonkey
07-26-2015 10:14 AM
yourrealdad
07-21-2015 11:13 AM
Iceman4193
07-15-2015 04:48 PM
Quick Reply: Can I add tranny fluid through shifter hole?
