Can this be deleted?
Old 02-12-2016, 08:13 AM
NMDesertRat's Avatar
What is this (RED ARROW AND CIRCLE)? I assume it's an A/C VSV...
Can it be deleted simply by looping the vacuum lines as illustrated with the BLUE arrows?
The black cylinder filter apparently fell off and is resulting in an audible hiss. It seems to be constantly sucking air. Probably not great without a filter.
Old 02-12-2016, 08:38 AM
scope103's Avatar
Valve, Magnet 88690-89132
http://www.toyotapartsoverstock.com/...869089132.html
$18.24 -- just fix it!
Old 02-12-2016, 08:51 AM
92ehatch's Avatar
You can delete it but if you use the ac then fix it. Your idle will be crap low without it and the ac running.
I also don't think it should be sucking air unless the ac is on
Old 02-12-2016, 08:52 AM
But.... I don't wanna. My A/c doesn't work and I can remove the top...
Fine! I'll replace it.
Thanks, Scope!
Old 02-12-2016, 09:55 AM
Right. That's why I assumed it was bad. I ordered one through toyotapartsoverstock. I'll delete it until I get it.
Calioutdoor
02-15-2016 08:19 AM
conehead
02-07-2016 11:30 AM
studeb
01-28-2016 08:08 PM
joshik
01-28-2016 07:59 PM
jkj2000
01-17-2016 01:29 PM
Quick Reply: Can this be deleted?
