Camo Painting
Camo Painting
I have a 86 4Runner I'm building and want to paint it camo. How should I go about painting it. Post pics of camo 4Runner or pickups and different styles their to do. Thanks
THe key is breaking up the outlineof your car....pattern is not as important as breaking up the lines of the truck...unless of course you want to match a certain pattern (hunting - real tree) (army - woodland) (marine - digi camo) whichever.
This is the only pic I have found so far, its a 1999 Tacoma, but it looks airbrushed, which means very professional, and VERY exspensive.... let me keep looking. see if I can get some good examples for you.
That looks good but no much for me. This rig is going to be a trail truck so I dont want anything to expensive. Thanks Post some more pics when you can
Okay after a little more looking around for you, this is what I got.
First Off, Classic Woodland Camo:
Next up is an example of realtree camo:
And then there is my least favorite Digi Camo: (This is the only decent example I could find)
okay, now for some trucks...
This is what I meant by breaking up lines, just change the siloutte of the truck, dont follow body lines or anything, this is desert camo, but same priciple appliesThis truck actually belongs to LOCKnGO her eon the boards.
Here is a pretty good Woodland look on Double Cab Taco
Here is Ryker's (1985 4Runner on the boards)Painted with Krylon from Wal Mart
Here is 91 4Runner's who may be on to the right idea, you may want to PM him to ask about those stencils....This is the base coat color that he painted the runner first.
Then he plans to stencil one of these three cmao patterns over it, again you may want to PM him to ask about the stencil, its a pretty slick idea...
There are many other ways to do it, and Im sure there are many tips and tricks, and probably even woodland camo stencils, or even painting kits out there for this kind of thing, I really don't know, but I hope this gives you some ideas....
~Chris
~Chris
Once the prep work is done - body work, remove all wax, sand old paint, etc.- it should be just a matter of applying a good automotive primer & start painting. Prep work is the key to a good paint job. There is a type of primer commonly referred to as "acid-etching" that can be very useful in painting an older vehicle where the surface is not perfect or there is the potential for rust that could not be eliminated.
As far as the pattern - don't make it symmetrical. The breakup of the vehicle outline is dependant upon the lack of an overall pattern. Some people who camo things themselves lay down a base (pick your color - OD green, brown, black, sand, etc) and then overlay the other colors on the base. You can even make cut outs of leaves branches, etc. from cardboard to assist instead of trying to free hand everything. One last thing - if you want to actually be able to hide it use a flat paint - do not use a clear coat or other layer that will make it shine. Things that shine are easily spotted.
Hope this helps.
Hope this helps.
if its a trail rig, theres som good primer i used on an old jeep for camo at walmart....just be sure to sand the gloss, and lay down a good coat of primer first..good luck
Home Depot sells rattle can camo paint. Not sure how it works, but it's supposed to come out of the can without getting all of the colors mixed. I bought some to paint a trailer I'm going to use for hauling my hunting gear around in, but I haven't had time to get it done. I'll post pics when I finally get around to it if it turns out o.k.
Follow along with this guy as he documents the best camo paint job I have ever seen.
http://www.tacomaterritory.com/forum...6&page=1&pp=30
Fink
99% of the work is all prep and sanding, you can do a rattle can job and be fine, krylon sells camo paint thats very good stuff.
The entire point in making the pattern is (for woodland) start by painting everything black, then paint the entire truck olive drab green (or a similar green), 2-3 coats! With sanding in between since this is the base layer.
Then work out a pattern, look at military clothing and trucks to help, but the pattern is there isno real pattern-every truck is different. Basically you break up the outlines of the truck, everything rounded and square should get camo on it and it should look like you threw big blotches of paint on when you set it up.
Practice on a piece of wood first to get the fell of it.
http://tacomaterritory.com/forum/sho...highlight=camo
There you go...You could substitute any colors instead of what he chose, but I think this is the best write up on "how to". Next spring mine will follow a similar pattern but with desert camo! Cant wait!!!
Doug
Doug
