camber bolts
Old 01-14-2014, 03:45 PM
Tugs's Avatar
camber bolts
Took my 89 4x4 pickup with a4 inch lift to the alignment shop today. It aligned perfect when i picked it up they told me the passenger side camber (the ones on the lower control arms) bolts wouldn't completely tighten up. The bolts were tight but not tight enough had anyone else ran into this? I was going to put a washer under the nut in hopes of getting enough to tighten it.
Thanks
Tugs
Old 01-14-2014, 04:09 PM
JohnnyCanuck's Avatar
I got an alignment before I moved here, they phoned me and said the camber bolts were loose but they should be able to get it sorted. When I got my out of province inspection done, the mechanic showed me that my camber bolts were tac-welded, really nice… Now I have to replace them, I'm think you might have to do the same.
Old 01-19-2014, 05:23 PM
Tugs's Avatar
Update, placed washers under the nut and tightened with a long 1/2" dive ratchet bam in business!
Old 01-19-2014, 06:03 PM
Erik Hinch's Avatar
Johnny,
I have some camber bolts if you need them, they are from a 1st gen 4Runner.
some drunk guy
08-03-2021 06:09 PM
Zach_trun
01-22-2020 04:42 PM
mistershmi
01-05-2016 11:07 AM
JUICE222
10-13-2015 08:50 AM
Jwp1
09-06-2015 11:03 AM
Quick Reply: camber bolts
