cam,valve,spring setup what do you think?
After talking to ted over at engnbldr.com im think i want to go with this set up what do you guys think? this is my DD anything would be great
StreetRV cam, O/S valves, Bronze guides, RV springs
StreetRV design is our 268C, it is 268? duration, .425"
gross valve lift.
The valves are 1.803" intake and 1.481" exhaust
my Q's are
what do you think my computer will do? if anything.
what should i have to run my timing at? stock right
also im going to port the exhaust and polish the intake any concerns
there?
thanks guys!
gross valve lift.
my Q's are
there?
thanks guys!
Computer shouldn't care. That setup is not very radical. I'm not sure if porting will gain you much unless you intend to race the 22re, especially with a 268 cam.
I'm running a 280 cam from LC Engineering with a 0.440 lift and the computer works just fine without any changes.
jerusry
10-19-2015 05:28 PM
