Cam Shaft Questions
Old 09-05-2010, 10:35 AM
BajaRunner's Avatar
Cam Shaft Questions
Well I have been having some running issues ever since I bought the truck and have pretty much gone through every test and procedure in trying to get the truck to run smooth, but am still unable to get it "perfect" in my mind.
The PO told me he had put an "oversized" cam shaft with the new head and valves. At the time, I didn't really think much of it, and didn't really care...
Now I'm sort of thinking it might have a direct influence in the erratic idle I am getting. My power is OK up high, but down low I swear I can barely get into the next gear without bogging. Once I hit about 3000 rpm the thing takes off, and runs great.
My questions are this:
1) For CA or street legal cams, would they be different from stock enough to cause an erratic idle?
2) Are there any stamps on the cam that I could read to figure out what the lift is, and who the manufacturer is?
3) Am I able to just swap in a stock sized cam without swapping valves/springs etc? (looking at 22re.com and lcengineering.com).
4) Would it explain why I am getting a "better" or "cleaner" idle when the ECU is not getting info from the O2 sensor, TPS, AFM? (open loop).
Here's a list of things I've done for those who may have not clicked on my previous 50 threads!!!
Replaced: O2 sensor with Denso, TPS (adjusted), PCV valve w/ grommet, plugs, cap, rotor, wires.
Tested: ECT, AFM, cleaned throttle body, IACV, Intake plenum, replaced all gaskets, intake tube.
Adjusted: Valves, timing
I think I've done a lot more but I can't remember everything
Thanks again for your help.
bigjstang
08-25-2021 12:41 AM
A2theK
01-10-2016 10:18 AM
88sasturbotoy
08-11-2015 01:56 AM
thefishguy77
07-30-2015 10:59 AM
cgilley
07-25-2015 10:55 PM
Quick Reply: Cam Shaft Questions
