Calling the carburator pros
Old 09-23-2011, 02:14 PM
Mr.Utah's Avatar
Starting my 22r, its purrs great. Once it gets warmed up, it goes to high idle. It will stay there until I tap the throttle, then it goes back down to normal idle of about 750 rpm. This happens after every acceleration, so at every stop light I have to tap the throttle. Bought my rig in January, have no idea of the history. Do I need to rebuild the carb or what?
This is driving me nuts.
New motor
New transmission
new almost everything
Thanks for your intelligent replies>>>>>>>>>>
Old 09-23-2011, 02:16 PM
xxxtreme22r's Avatar
sounds like either the throttle linkage is sticking possible a bad/frayed cable, choke too tight or the carb plates are sticking on the manifold. Could also be a worn out spring assembly on the throttle.
Old 09-23-2011, 02:48 PM
BMcEL's Avatar
Not a pro, but...my 20R did exactly what you're describing after I relocated the throttle cable for my body lift. I put a return spring on the linkage and it hasn't done it since. Not sure if it's just masking the problem but still no issues a year and a half later.
- Forgot to mention mine stopped idling up on it's own after it warmed up when I seafoamed it...FWIW.
Old 09-23-2011, 09:43 PM
Mr.Utah's Avatar
Thanks Gent's. I will check it out. You guys Rock!
suppra87
07-15-2021 05:15 PM
justdifferentials
14
06-11-2017 08:36 PM
viesail
09-21-2015 06:00 AM
sonorn67
09-19-2015 05:39 PM
TACORICAN
Marlin Crawler
09-18-2015 09:30 AM
Quick Reply: Calling the carburator pros
