Cable Question
Old 02-22-2008, 08:08 PM
Tempeboy's Avatar
Question Cable Question
What is the wire that goes from the positive side of the battery to the fuse box called?
Reason being is that it is getting worn and I would like to replace it, It seems important for such a thin wire, because if its not hooked to the battery the engine wont turn. It's been spliced a few times and I would just rather replace it.
Old 02-22-2008, 09:06 PM
toytech76's Avatar
I dont think you can buy that seperately. Its the wire that powers your fusebox. You can get a heavy gauge wire with round connectors on each end and replace it. You should be able to see where in the fuse box it attaches to
Old 02-22-2008, 09:10 PM
Elvota's Avatar
That wire should have a fuseable link for a section of it. That needs to be replaced with same. Possibly a inline fuse of similar amperage could also work.
For ideas and option in regards to this wire, search "Big 3 Upgrade" here on YT.
Old 02-22-2008, 09:32 PM
Staff
DeathCougar's Avatar
No fusible link between the battery and the fuse in the fuse box. That cable always seems to break near the battery cable from corrosion.
kazuya2416
04-05-2024 02:17 AM
okamikai
04-30-2018 10:19 PM
altydog
07-28-2015 10:20 AM
CanRunner
07-20-2015 01:29 PM
shar
07-09-2015 12:38 PM
Quick Reply: Cable Question
