YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-17-2008, 08:28 PM   #1 (permalink)
A/C Techs Help Needed
My a/c quit blowing cold 50 degree vent and now only blows cool 70 degree vent. So I hooked up my gauges and I'm getting 40 on the low and 250 on the high, when I rev it up to 2,000 the low goes to 10-20 and the high goes to 300-330 all the lines are hot except the one from the compressor low side to the expansion valve. Also my expansion valve use to make a hissing noise and now it doesnt. Now heres the part I dont understand when I shut off the a/c the pressures dont equalize the low goes to 90 and the high goes to 250. I think the expansion valve maybe bad or there is a restriction somewhere in the system. Also I converted the system to freeze 12 last year and it worked fine for the whole summer and up untill last week. Any Thoughts?
854x4 is offline
Sponsored Links
To remove this ad, register today!
Old 05-18-2008, 07:52 AM   #2 (permalink)
Certainly sounds like the expansion valve is restricted, be the logical place to start. I have no experience with Freeze 12, I always convert to R134a. Was the system properly evacuated when you recharged last time?
motoriderbc is offline
Old 05-18-2008, 10:22 AM   #3 (permalink)
abecedarian's Avatar
Location: Climbing cell towers- the deadliest job in America
Does the accumulator a.k.a. receiver/drier have the sight glass on it? If so, do you see any bubbles or liquid bouncing around?
Either way, it sounds like a dissasembly is necessary.
__________________
...relax and rest assured: my name is not allan.
Save the world! Protect the environment!! Conserve nature!!!! Eat a vegetarian / vegan.
See, I'm being green.
Quote:
Originally Posted by SwampThing View Post
....But I'm happy to report that I have yet to have a good measure of sense knocked into me. Even when I was testing out my hardhat by runnin full speed into a brick wall, I am still sense-less.
abecedarian is offline
Old 05-18-2008, 10:37 AM   #4 (permalink)
Yes the system was properly evacuated and recharged to the proper amount and the sight glass shows the freon moving just like it should. Here is the weird thing it did the same thing last year, the expansion valve quit making noise and the a/c quit blowing cold so I replaced the drier pulled vacuum on the system and recharged and the expansion valve started making the hissing sound and the a/c worked great. So I think I may have to replace the expansin valve flush the evaporetor pull vacuum and recharge. Also does anyone elses expansion valve make a hissing sound my 85 also does it with a full charged R12 system and it works great.
854x4 is offline
Old 05-18-2008, 10:49 AM   #5 (permalink)
mine hisses but only when the A/C first turns on or after I turn it off and the refrigerant equalizes in the system.
Also, mines an 88 converted to 134.
But, you're saying it did it last year when the same thing happened. I'd have to guess you've got some rust or congealed (thickened) oil in there that just happens to hit the orifice just right every now and then. So yeah, you need to flush it out good.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Any Ford techs on here? Ironmike4x4 Off Topic Talk 0 12-05-2007 05:32 AM
A/C Techs Help Needed 854x4 86-95 Trucks & 4Runners 8 07-08-2007 07:41 PM
Any HVAC techs here? Ironmike4x4 Off Topic Talk 1 12-16-2006 01:22 PM
Allignment techs please look JEDI87 95.5-2004 Tacomas & 96-2002 4Runners 2 07-19-2005 01:02 PM
dealer techs Toys-R-Us 95.5-2004 Tacomas & 96-2002 4Runners 2 03-30-2005 06:51 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
