Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
A/C Techs Help Needed
First a little history the truck is a 86 toyota 22RE. I replaced the a/c pump 6 months ago along with the reciever drier, the old pump was bad plus it was low on freon. Had a shop recover and store the remaining freon and then put it back after I installed everything. It was still low so I put a can in and it was right in spec and really cold 40 degrees. Now 6 months later it only gets to 80 when its 110 outside. I checked the pressure and when I hook up the gauges both are at 150psi then I turn the compresser on and the low side is 40psi and the high side is 250psi.Its not low on freon so I dont know what the problem is? Also when the shop put the freon in the truck they didnt pull vacuum like they should of, but it was a family friend so you all know how that goes. I'm a a/c tech so I know a little about this but with my lack of a recovery machine leaves me stuck. My theory is there is air or moisture in the system. I plan to recover , vacuum and recharge with freeze 12 but I would like to get a second opinion? Thanks
| Sponsored Links |
#2 (permalink) |
Uh, the first problem is you re-used refrigerant that is usually a no-no. Yeah refrigerant doesent wear out, but it can be contaminated. personally I'd start over w/ some new refrigerant and make damn sure you pull a good vacuum on it, I'd try this first and see whacha ya got.
__________________
Airaid cold air kit, airaid throttle body spacer, Jardine cat-back exhaust, Alpine 9815 receiver, two pair polk momo component (mm6) speakers, two polk 12" subs (dx12) Alpine dvd changer, Alpine xm radio module, lightning audio 1.0 farad capacitor rockford fosgate (two) 250@2 punch amps, (one) rockford fosgate 200@4 for the components, all monster cable wiring for ai-net stuff+power wiring. Dynamat all over the place, Bridgestone REVO's 255/70/16 mated to 16x8 trd Ivan Stewart wheels |
#3 (permalink) |
I know the refrigerant wasnt contaminated (original 1986)and it went through a recycler, but with the guy not pulling a vacuum its probaly contaminated now. R-12 stoped being produced around 1995 so all refrigerant now is mostly used and recycled.
#4 (permalink) |
so are you saying there was no vacuum put on the system after you installed the goodies? if so, you need to just start over.
#5 (permalink) |
What did you do with that antique expansion valve?
#6 (permalink) |
Expansion valve was never replaced
#7 (permalink) |
And the fan clutch?
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| attention toyota techs | woody2474 | Off Topic Talk | 9 | 05-08-2007 02:45 PM |
| Any HVAC techs here? | Ironmike4x4 | Off Topic Talk | 1 | 12-16-2006 01:22 PM |
| any ipod techs in the house? | Brendan | Off Topic Talk | 4 | 07-30-2006 08:54 PM |
| Allignment techs please look | JEDI87 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-19-2005 01:02 PM |
| dealer techs | Toys-R-Us | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-30-2005 06:51 AM |
