a/c lines
a/c lines
95 3.0 4Runner, anyone got any pics handy of the A/C lines? I bought some lines off ebay but it looks like maybe for a 4cyl or older model (advertised as 89-95) the lines I received had the receiver/drier further to the right than the current one is now. I looked at the drawings online from several Toyota parts dealers but that's just it, they're drawings and do not help me enough. Where is the pressure switch, on a line? I do not see an unplugged connector anywhere, the drawings show it on the shorter line from the r/d but the line that is still attached does not have any switch and it looks like it's the one from the factory so I doubt someone switched it.
thank you in advance!
The pressure switch is in Cooling Unit (inside the cab). http://web.archive.org/web/201102052...19pressure.pdf
Because the position of the compressor is different between the 3VZE and 22re, the lines are also different.
Are you starting from no A/C at all?
I have the rec/drier, short line from r/d to condenser, suction hose from compressor to evap and that's it. I think all I need #13 and #12 from this drawing http://www.midatlantictoyotaparts.co...S/8409080.html
i just bought the discharge hose off ebay
WTB[NorAtl]: Looking for 5 speed 4x4 tranny
4.34runner88
02-21-2016 04:23 AM
FinallyOffRoad
02-19-2016 06:29 AM
