A/C fuse blows
Old 06-12-2007, 03:48 PM
Bigblock's Avatar
A/C fuse blows
After the 3.4 swap,the fuse will blow.Mike's at ORS harness,proffesionally installed by,your's truly.Compressor can be plugged in or not,it still blows the fuse.I have not tried a larger fuse,it will wait untill you mash the gas to blow.Anyone?It's 100 degrees way down here.
Old 06-12-2007, 04:22 PM
mudbutt's Avatar
It doesn't blow till you hit the gas?
This sounds like the compressor clutch is rubbing against it's self shorting out. Don't install a bigger fuse or you will start to burn wires.
Old 06-12-2007, 04:27 PM
mudbutt's Avatar
Originally Posted by 3yotys
Compressor can be plugged in or not,it still blows the fuse..
Doh, didn't read this. Try another amplifier and inspect the wiring for a short, my personal method is a headlamp soldered on the back of a blow fuse, bright light=short, light out=found your problem.
Old 06-12-2007, 04:28 PM
Bigblock's Avatar
I thought that too,but after unplugging the comp. it still blows.
Old 06-12-2007, 04:32 PM
Bigblock's Avatar
You can unplug the evap pressure and the evap temp and it will not blow.Or you can unplug the a/c exciter and it wont blow.I'm thinking the exciter.I have another out of a 89 pickup I'll try and let you know.
Old 06-12-2007, 04:33 PM
Bigblock's Avatar
Exciter ;I mean the amplifier.
Old 06-12-2007, 05:39 PM
Bigblock's Avatar
The other amplifier does the same thing.Evidently one of the wires in the aftermarket harness is crossed.Hope not,I've bragged on ORS so much.Although anyone can make a mistake.BTW I called ORS and got no answer.I guess they were closed.
Old 06-12-2007, 05:43 PM
Bigblock's Avatar
The other amp was also adjusted diff it blew the fuse the second the a/c button was touched.
Old 06-12-2007, 07:21 PM
Bigblock's Avatar
Evidently nobody has had this problem,Murphy's Law.Anyway the wire from the amplifier to the comp. was grounded rather well.I didn't bother finding out why.I ran a new wire,and fixed the problem.It only costed me the spare amp and some time.It now works as new.Thanx
RyanJ989
11
04-07-2021 09:41 AM
Bourbonblues
12-15-2017 05:43 PM
Ktm526
10-07-2015 05:14 AM
Tacoma1313
09-08-2015 01:27 PM
Gone Fission
09-04-2015 12:18 PM
Quick Reply: A/C fuse blows
