A/C conversion R12 to 134a help
Old 07-11-2010, 06:58 PM
4runner fanatic's Avatar
Hey guys, I have an a/c question. It's getting hot and I would like to get it working again in my 1990 4runner. I wanted to convert it to 134a. I bought the adapters and made sure all of the r12 was out of it. What else do I need to do? I bought the 134a already but I wanted to make sure it was going to work before I go wasting my money. Any help would be greatly appreciated.
Old 07-11-2010, 07:00 PM
dieselloco427's Avatar
I'm pretty sure as long as all of the R12 is out and you are sure that there are NO LEAKS!! you can fill the 134a in through the low pressure port.
Old 07-11-2010, 07:02 PM
Alright thanks. And the low pressure port is the one closer to the firewall corect?
Old 07-11-2010, 07:10 PM
Correct - it's the one with the BLUE cap, and it's taller and slimmer than the high pressure port.
Old 07-11-2010, 07:12 PM
thralldad's Avatar
I just completed this on mine. I took all the hoses off and cleaned and replaced all the o-rings. Remove and empty the oil from the compressor. Clean out the evaporator and condensor with denatured alcohol and blow everything out with compressed air. Replace the receiver-dryer. Reassemble,add ester oil and vacuum down and check for leaks.Recharge with R-134 and enjoy! I'm getting 42* at the vent by doing it this way. It took a good day to do this.
Old 07-11-2010, 07:16 PM
Damn, I was hoping I could just put the 134a in and it would work. Will it still work if I choose not to clean it out? All of the r12 is out now. Also does the oil need to be changed or can I get away with letting it in?
Old 07-11-2010, 07:20 PM
thralldad is right, you should clean out the system and find out what caused it to stop working in the first place (if it failed under the use of R-12). At least put a vacuum on it to make sure there are no leaks, and if there are none, use a refridgerant with a seal conditioner & compressor oil. I wasted 2 cans of 134 on my brother's Civic because I didn't know the compressor seal had gone bad. As for the compressor oil - not sure about that. I think the oil recirculates with the refridgerant... I'm prob wrong about that though.
Old 07-11-2010, 07:25 PM
modlite's Avatar
If you use Freeze 12 you don't need to clean out the compressor or anything, and it has very similar characteristics to R12.
I was going to convert mine, but then I decided otherwise. The R12 cools much better, and i need everything I can get in my big 4runner cab. Plus i read that R-134 puts a bigger load on the motor because it's hard to compress, and I can't afford to put much more load on my motor so I'm sticking with R12. You can get it on ebay, and then take it to a "qualified" person to put it in, or if you want to risk it just put it in yourself.
Old 07-11-2010, 07:30 PM
thralldad's Avatar
Ester is compatible with R-12 and 134. Pag will cause your oil to gel and smoke your compressor. Your leak is most likely an o-ring and the originals are black and the R-134 ones are green. The originals are probably hard and brittle by now,therefore leaking. It's some work but that COLD air is super nice in the Texas heat!
Old 07-20-2010, 12:07 PM
I found that the 134a would work fine in mine. All I did was drain all the r12 out and it worked fine. I've been using it for over a week now. I never had a leak!
The following users liked this post:
DJames (08-16-2022)
Old 07-20-2010, 12:14 PM
TORTIS's Avatar
Do your self a favor and go spend an hour reading on the forum at ACKits.com. Nice folks, like here on Y/T.
They cover all of it.
Old 09-28-2012, 09:54 PM
YOAKUM_AZ's Avatar
Hi guys, i've been reading that the condensor needs to be replace when converting to r134a, and that the accumulator can be flushed instead of replacing it. I've already flushed the hoses and evaporator, and added new o-rings from a retrofit kit i bought. So is it the condensor or accumulator that needs to be replaced? Was planing to flush the accumulator tommorrow.
Old 09-28-2012, 10:48 PM
bob200587's Avatar
It cost me $65 dollars to have the conversion done, flushed and filled with 134.
Totally worth it to not have to worry if you are doing it right.
Old 09-30-2012, 01:06 PM
YOAKUM_AZ's Avatar
i payed $32 for the retrofit kit(all a/c o-rings, ester 1oo, and new ports with caps).
$17 for 12oz of a/c flush, so about $49 dollars while learning how to fix/maintain my a/c system as i service it. I'm kinda the cheap one in the family, but still work for quality. Plus the shops around here charge around $80, unless i drive all the way to el centro.
dmw310 (06-23-2020)
Old 09-09-2016, 03:55 PM
dffraser's Avatar
I have a 1984 Toyota pickup and need to replace my AC condenser. Toyota no longer stocks the part, and I have been unable to find an aftermarket one either. Any suggestions?
Old 09-09-2016, 06:51 PM
nbl300's Avatar
Post in the wanted section or look in the part outs?
Old 09-10-2016, 01:18 AM
YOAKUM_AZ's Avatar
a simple search just showed me a few for yours online , '84-'89 are all the same from $90-$210 recommend denso since they'll be the closest measurements and the fact some of Toyota parts are made by them that they out source. Unless your fine with used ones for $15-$40.
Old 09-12-2016, 03:39 PM
SnapMech's Avatar
You really should go get vacuumed down and filled correctly. I can almost guarantee you there is moisture trapped in your system. That will corrode and cause failures. Also filling from the low side is fine, but the issue is that you have no idea what the high side pressures look like. There is a volume difference between r-12 and r-134, and the high side pressure will show you when the system is up to the correct pressure. You cannot put the same amount of r134 in as you had r12..
Old 04-19-2017, 10:05 PM
jhowland's Avatar
r12 to 134a
I'm converting to 134a in my 92 pickup. What is the best oil to put back?
Old 04-20-2017, 06:22 AM
scope103's Avatar
PAG 45
Here's everything I know about A/C: https://www.yotatech.com/forums/f116...-r134a-284801/
Quick Reply: A/C conversion R12 to 134a help
