A/C compressor removal
Ok, trying to replace the A/C compressor on a 93' 4runner; I guess there is absolutely no way it comes out the bottom??? I'm trying to remove the P/S pump, but the pulley nut wont budge. Are there any suggestions how to remove the P/S pump PULLEY so I can remove the pump. Looks like the bolt behind the pulley wont come out far enough to remove the pump without hitting the pulley. Any help is appreciated.
OK..that was not fun at all....no wonder we were quoted $1,000 for this job! Removed the P/S pump and pulled the compressor out the top; had to pull and re-install the clutch while it was still in the rig. Off to get it recharged. Thanks all.
skoti89
07-08-2015 12:05 AM
