c clip front axle help!
Old 10-10-2007, 04:45 PM
dcmbsc's Avatar
i am changeing my front axle and i have gotten to the point where i need to take the c clip off . i need a diagram , i cant get to the c clip , i need pix , help!
Old 10-10-2007, 04:52 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Does this help?
http://personal.utulsa.edu/~nathan-b...onandaxle.html
EDIT: I suppose I should have asked...what seems to be the problem? Why can't you get to it?
Old 10-10-2007, 04:56 PM
Sponsor
Tofer's Avatar
use a pair of needle nose pliers to open the clip and slide it off.
Old 10-10-2007, 05:06 PM
tc
tc's Avatar
Or a screwdriver under one end and work it around until it's out of the groove.
Old 10-10-2007, 05:34 PM
dcmbsc's Avatar
can you pull the cones out with a wheel puller, because they wont come out by hitting them?
Old 10-10-2007, 05:42 PM
FredTJ's Avatar
How area you hitting them and with what ?
Fred
Old 10-10-2007, 05:44 PM
dcmbsc's Avatar
i am hitting the stud with a brass rod
Old 10-10-2007, 05:54 PM
FredTJ's Avatar
Try hitting the side of the flange itself.
Mine popped right off. No problem at all.
Fred
Old 10-10-2007, 07:06 PM
dcmbsc's Avatar
it wont come out , i have to get a screw puller outter tomarrow
Old 10-10-2007, 07:12 PM
4Crawler's Avatar
Cone washer removal tips:
http://www.4crawler.com/4x4/CheapTri...eWasherRemoval
Not sure which c-clip is being referred to, but some tips on the page above.
oldirtydirt
02-23-2020 09:30 AM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
Cabell
07-24-2015 12:14 PM
Quick Reply: c clip front axle help!
