Bypass load leveler
Bypass load leveler
Is there any way I can bypass the load level bar that goes from the axel housing to the frame? Can I just make a connecting line for the brake lines?
Is this what you're looking for? http://www.off-road.com/toyota/cheaptricks/brakevalve/
http://www.imagestation.com/7624219/3932997331
You need one of these.
http://www.imagestation.com/7624219/3932997315
Remove the line from the rear to the front and plug the tee.
http://www.imagestation.com/7624219/3932997273
Then remove the LSPV and connect the line to the rear brake tee.
I will be adding a second manual valve in the rear as the one at the master is adjuted all the way out.
I removed mine because I added rear disks.
http://www.imagestation.com/7624219/3932997292
kawazx636
10-06-2021 03:03 PM
smilen724
13
11-08-2015 04:11 PM
kcaudill
10-10-2015 02:39 PM
charlie_fong
09-27-2015 10:06 PM
