BVSV (Bimetallic Vacuum Switching Valve)
Old 01-24-2007, 10:24 PM
Ebin's Avatar
Angry BVSV (Bimetallic Vacuum Switching Valve)
During the course of doing a HG replacement I broke the old BVSV breaking it down and I broke the new one putting it back together (yes, I know I am a Dumbass). I think I understand what this valve does. How critical is this valve and can I get by without for the time being (winter time and all). If I just install it with no vacuum lines hooked to it? Why would they design this part with the tips so easy to break off? (rhetorrical question)
Old 01-25-2007, 09:57 AM
BC Rider's Avatar
Ebin:
If this is the BVSV that runs the canister purge it should be fine without it. IIRC it is just to control evaporation emmisions when parked. However, I would block off the ports to help ensure you don't end up with vacuum leak.
Old 01-26-2007, 01:13 AM
the_supernerd's Avatar
I am not sure about the V6, but on a 22R there is a BVSV controls the EGR. Running without the EGR will cause pinging. If you are not going to get a good BVSV, then you would probably be better off attaching the hoses together so the EGR works all the time instead of not at all.
Edit: I just looked up the 3vze manual on Autozone.com and I noticed that the BVSV controls flow to the charcoal canister like BC_Rider said. He is right, just plug the vacuum line and you will be fine.
montanatruck
02-26-2017 07:07 AM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
voiddweller
07-15-2015 03:56 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: BVSV (Bimetallic Vacuum Switching Valve)
