Buzzing Right turn signal ?
Old 04-05-2011, 10:26 PM
silverstar4life's Avatar
Question Buzzing Right turn signal ?
Installed a new deck today ( new to me ), turned lights on, all dash lights worked, flipped the switch to turn right and this buzzing, irritating noise came from the internal fuse box under the driver side dash? Tried left signal and it just clicked but abnormally fast along with the hazard lights when i turned them on? I dont think the deck has anything to do with it, same as before just not broken. i have not checked the fuses under the dash ( dark out ) all the fuses under the hood were fine though.
its a 1986 toyota 22r, if anyone has any suggestions as to what the issue may be, it would be greatly appretiated.
Old 04-06-2011, 12:44 AM
Sportsmanphil's Avatar
Im confused.. I installed a deck too, but it was attached to my house.
Im going to guess your turn signal relay is zapped which is a cheap easy fix... but am intrigued to what a 'deck' is on your yota?
Old 04-06-2011, 12:46 AM
prorunner's Avatar
A deck is a stereo. You signals will flash fast if your bulbs are blown or fuses have blown.
Old 04-06-2011, 12:50 AM
Ahh thats right.....I remember them being called a tape deck... but thought the lingo went to head unit when CD's came out.....HAHA..
My vote is flasher relay.
Old 04-06-2011, 06:09 AM
drmix's Avatar
Originally Posted by prorunner
Your signals will flash fast if your bulbs are blown or fuses have blown.
X2. Had this problem on my pickup when I bought it. Checked all the bulbs and had a left front turn signal out. Replaced it then it started flashing normal
Old 04-06-2011, 09:17 AM
thanks for all the replys, i found the problem, rear left light wasnt hooked up properly
ghostmoney
01-28-2018 11:42 AM
Shoua
13
05-22-2016 05:19 AM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
PopsDad1
07-30-2015 02:21 PM
Quick Reply: Buzzing Right turn signal ?
