bushings
Old 02-12-2008, 07:27 PM
acerbis's Avatar
bushings
when i make a turn it sounds like something in the front suspension/drive system is loose or maybe more like a "shift". Does this mean that i need new bushings. There is nothing loose down there because I just got done replacing the timing chain and triple checked the tighness of the surrounding bolts. What bushings do you guys recommend?
Old 02-12-2008, 07:49 PM
bry-an's Avatar
if its a loud popping grinding it could be the steering stops, so just put a dab of grease on them.
if its a rattle on really sharp turns it could be your CV's
if it happens when you got on like a road with lots of bumps and pot holes but is straight then it is probably something like a loose bolt
I dont know if you got new tires anytime recently but they could be rubbing if they are large.
hope this helps
bryan
Old 02-12-2008, 08:17 PM
Jay351's Avatar
Check your idler arm - might be causing some noises if its very worn
Also check your wheel bearings, mine had not been touched in a LOOONG time, had tons of play and causes some pretty horrible noises.
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
punks_is_4x4
02-26-2016 04:29 PM
JRB4Runner2015
09-20-2015 12:29 AM
Pocoyota
09-08-2015 02:41 PM
Quick Reply: bushings
