Burning Steering Fluid on Startup?
Old 02-06-2009, 08:28 PM
dieselloco427's Avatar
Question Burning Steering Fluid on Startup?
Evening fellas:
This has been puzzling me for some time now. On startup either in the morning or after the rig has been sitting for a while, I'll start it up and get a bluish grey smoke out the exhaust. Its not oil burning, because it does not smell like oil - and its not that thick white smoke that oil makes. It smells like ATF - and since the tranny isnt connected to the engine in a way that would allow fluid to get to it - that leaves the p/s pump and those two little vacumm hoses to 'blame'
Is it possible for fluid to get in those lines and sucked into the engine on startup? My p/s pump is leaking a little - so I guess I should plan on replacing it if I want to resolve the smoking problem, and all the fittings on the steering gearbox are leaking too - looks like I've got another project
any additional thoughts before I dig in?
Old 02-06-2009, 08:52 PM
scuba's Avatar
power steering uses ATF. Viaola
Old 02-06-2009, 09:02 PM
iamsuperbleeder's Avatar
I have heard about the idle-up valve on the top of the PS pump failing and letting ATF into the intake through those lines, although I have never witnessed it myself...
that's the only logical place it could be coming from though, as you explained
Old 02-07-2009, 07:50 AM
alright. I'll pull the lines off while I'm changing my oil and see if they're filled with atf. I have a feeling that valve is the problem.
Old 02-07-2009, 07:54 AM
4Crawler's Avatar
Easy enough to cap off the fittings where those lines attach to on the intake and see if the problem goes away or not:
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/7.html
GSGALLANT's Avatar
Yes. That valve can fail and lead to ATF from the power steering system getting sucked into the intake. Not very common, but I've seen it happen.
Old 02-07-2009, 11:49 AM
DupermanDave's Avatar
does the 22re have the ability to burn power steering fluid as well? When I did the head job, I didn't really see anywhere the PS pump could leak into the intake or cylinders to burn
Old 02-07-2009, 12:12 PM
yes, same senario
The PS pump has a valve on the top of it that has 2 vaccum line running to the intake manifold. When your steering is under load, it puts tention on the PS belt, therefore bogging the motor down a little. This valve sences that, and ups the idle accordingly, thuse, no bogging down of the motor. BUT, if the valve fails internally, I can leak the PS fluid (ATF) into the intake manifold through the vaccum line and then burn it as the motor ingests it.
Same stands true for both the 3.0 and the 22re
Old 02-09-2009, 03:13 PM
yep - that valve is shot on my rig. I took the vacuum hoses off and fluid spilled out of the hose. and slowly dripped from the valve (1 drip every minute or so) No wonder I had to keep adding ps fluid
Does this valve come with a new pump?
old87yota
10-25-2015 02:15 PM
Up&Down
08-11-2015 10:04 AM
JHalcyonM
08-04-2015 01:19 PM
gmonnie123
07-26-2015 02:44 PM
rushw
07-18-2015 01:46 PM
Quick Reply: Burning Steering Fluid on Startup?
