burning rubber smell?
Old 03-09-2008, 02:09 PM
1992toyota4x4's Avatar
recently a few times i have gotten out of my truck after a small drive (mostly on the snow and pavement) to smell burning rubber, not a strong strong, but enough to smell it, coming from the rear driver side tire area, i checked the tire all over, not even warm anywhere, i havent gotten under the truck yet to see but i was thinking maybe the exhaust is touching one of the rubber hangers? i dont think its the tire so what else can it be? ill be getting under the truck when it gets warmer. any similar experiences?
Old 03-09-2008, 03:34 PM
07sbock's Avatar
Leaky valve cover gasket.
Old 03-09-2008, 04:13 PM
with a burning rubber smell from near the rear tire?!
Old 03-09-2008, 04:15 PM
MMA_Alex's Avatar
you sure its not the slipping clutch smell? its rubberyish
Old 03-09-2008, 04:26 PM
clutch is new, and isnt slipping, its coming from the rear of the truck, i just dont know where yet lol, its too cold to get under the truck right now.
Old 03-09-2008, 04:29 PM
it smells like i just did a burnout but not a very strong smell.
Old 03-09-2008, 04:43 PM
bigarms23's Avatar
it sounds like the clutch to me so adjust the linkage and since yours is new make sure it was installed right
Old 03-09-2008, 04:49 PM
ok thanks all ima look into it
Old 03-09-2008, 04:51 PM
shancerlelby's Avatar
man, check the spare under your truck if its in there, those things shift and hit the exhaust so often on our trucks.
Old 03-09-2008, 04:53 PM
SwampThing's Avatar
New clutch doesn't smell like burning rubber. Smells like roasting brake pads (asbestos). Trust me. Just roasted 3 clutches on my dodge. 750hp/1010tq outta that cummins powerhouse with a heavy foot doing 3rd gear 4wd launches tends to do that!
thats what ive been saying its coming from the back of the truck lol... thanks man. ill look at it.
Old 03-09-2008, 05:00 PM
dubweiser's Avatar
i sometimes get the same thing with my runner.....could never figure it out, i'm gonna check my spare tire too
Old 03-09-2008, 05:05 PM
Dare44's Avatar
mine does it to, but it is from brake stances hahahaha
Old 03-09-2008, 05:11 PM
Marc's Avatar
I was going to post about this last week but figured no one else would have a similar problem.
I smell burning rubber from the right rear tire area.
I haven't seen anything obvious but it's been too cold and snowy to lie under the truck.
Old 03-09-2008, 05:36 PM
js9924's Avatar
I would guess that the exhaust is touching something. One time in high school my friend had a plastic bag fly under his car and melt to the muffler it stunk for weeks. good luck.
Old 03-09-2008, 05:48 PM
bry-an's Avatar
check and see if your ebrake is frozen.... if its only coming from the one side of trucks , specifically when it is cold out, it could be that the light is going out but the actual brake is not releasing fully couldnt it?
Old 03-10-2008, 07:05 AM
Marc's Avatar
I don't think that's my problem. It smells like burning rubber not brake pad, and my brake drum is not hot.
Old 03-10-2008, 03:08 PM
mine either, and i dont have a spare tire, still havent gotten under to have a look yet, but drums arent hot, no spare tire, still think its a rubber mount or something, will post if/when i figure ito out
Old 03-10-2008, 04:07 PM
Luvmeye22re's Avatar
Maybe it's a Canadian thing Seeing as the exhaust comes out on the opposite side (If you are calling the pass. side the right side) that's a tough call. IF v6 you might see if there is a hanger for the crossover somewhere on the right side. Otherwise, that's just strange
Old 03-10-2008, 09:09 PM
mr_schuster's Avatar
Check your drive belt tension???
Quick Reply: burning rubber smell?
