bumper issue
bumper issue
my front bumper is kinda loose on one side and i want to tighten the bolt, the one closest to the wheel, is that the right bolt to look at? and ifso, everytime i try to adjust it i think i am going to break something cause it bends alot, is this right????? and is there any way to adjust it?
BE CAREFUL!!!
I replaced my bumper a couple months ago and found that the threaded holes in the frame were rusty and full of dirt.
The bolts were not easy to remove and I needed to be very careful to not break them off.
I suggest that you thoroughly spray them with some type of penetrating fluid and let them sit overnight, then carefully remove all the bolts and "chase" the threads with the proper size taps.
You can do them one at a time so that you won't have to remove and re-align your bumper but, it would probably be quicker and easier if you did remove it.
Good Luck!
Good Luck!
jasonty
41
12-23-2018 01:00 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
