Broken wire between fuel filter and oil filter...What's it to?!? SEE PICS
Old 10-26-2009, 10:02 AM
jared63401's Avatar
Hey, I was replacing my head gasket and timing chain and in the process snapped a wire off the main wire harness and can't figure out where it goes or where the other section of wire went. It's on the main wire harness and is situated between the fuel filter and the oil filter below the EFI unit. Check the pics......Does this need to be reconnected??
Close up of wire
Location in the engine compartment
Old 10-26-2009, 10:05 AM
Elton's Avatar
id be more worried about that crappy fram oil filter
Old 10-26-2009, 10:18 AM
Junkers88's Avatar
I think it might be the wire that goes to the oil pressure sending unit, should be a sensor right around the oil filter somehwere.
Old 10-26-2009, 11:11 AM
sb5walker's Avatar
Maybe to knock sensor, which is just to left (toward back) of oil filter. Oil press sender is below oil filter.
Old 10-26-2009, 11:20 AM
iselloil's Avatar
Dump the fram
Old 10-27-2009, 03:03 AM
Ride-2-Live's Avatar
What kind of oil filter should be used?
Old 10-27-2009, 03:48 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
That's the kind of question that opens the proverbial can of debate worms. You'll get a lot of opinions on that matter. A quick YT search will give you some clue.
Toyota, WIX, Amsoil, Mobil1, and more. I use WIX. They're reputably good, quality filters with the anti-drainback valve. And, they're relatively inexpensive and doesn't require a trip to the dealership.
Hard for me to tell from the pic what the wire is. A broader view would help to exactify.
peapicker's Avatar
TOYOTA FACTORY OIL FILTERS ONLY! There are many reasons. And there black and say Toyota on them Thought I would get the ball rolling on the subject.
Old 10-27-2009, 03:49 AM
thook's Avatar
(What'd I tell you?........)
Old 10-27-2009, 09:23 AM
sb5walker's Avatar
Tons o oil filter info:
https://www.yotatech.com/forums/f116...filter-190242/
Old 10-27-2009, 09:57 AM
Lumpy's Avatar
Back to the topic of the original question...That would be the knock sensor. Kinda need that.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
toyota32
07-06-2015 05:42 PM
colinmil
07-06-2015 04:03 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Broken wire between fuel filter and oil filter...What's it to?!? SEE PICS
