broken lug stud (plural), safe to drive?
i've been driving 6 years, including offroading, with 1 broken lug (out of 6) on one of my wheels. i have felt comfortable since day 1 with 1 lug missing. but tonight i broke another stud on the same wheel. check the picture to see which 2 are broke. think this is safe to drive with this pattern missing? or do i have to tear it down now to fix these. unfortunately, i'm pretty sure what you're all gonna say.
I have one broken on my front left from a friend taking it off to do my brakes. One on my rear right from a friend putting my new wheels and tires on. I have had zero problems just make sure the rest are torqued down properly regularly. Just drove from Oklahoma to Georgia in it with no problems.
Well ultimately if your not comfortable with it being the way it is change fix them. I wouldn't be concerned unless you were on three seeing how many cars run on a standard four. 0.02
U would most likely be fine with just those 4... but there are 6 for a couple reasons, and one of those is to keep that alloy wheel from warping.
Seriously...it shouldnt take more than an hour to fix them... not that big a deal.
User Requested Ban
yeah, lots of vehicles come from the factory with only 4 lugs... theire called Honda's, and have a 13" tall tire on them
dude comon, is it worth risking your life over?
bad things happen when tires fall off...
and no that's not flex
I would drive with one missing, no problem. But 2? What if a third breaks at highway speeds? Then you're screwed.
