Broken exhaust pipe.
Found out my down pipe broke off at the flange to the cat. What would the most cost effective fix be? Just a new down pipe or is there a way to attach a new flange?
I see a very valuable cat take that thing to a metal recycler and collect lots of cash (before someone steals it), then go to the muffler shop and have a cheap one welded on. You'll likely not be out any money or close to it (unless you live in Commyfornia)
yeah that's maybe a $20 fix at a muffler shop
all they'd have to do is unbolt the cat and move it out of the way, clean up the flange and the pipe right there, and run a bead around it, and it'll be good to go
Oops forgot about this thread.
What makes this one so valuable over some other one?
Well I replaced my exhaust gasket and it must have broke loose from moving the down pipe around.
kawazx636
07-03-2023 03:03 AM
