Broken Body Mount
Old 12-29-2007, 08:09 PM
az4x4runner's Avatar
Exclamation Broken Body Mount
I noticed this quite a while ago, decided maybe I better fix it.
It is on the drivers far rear. Only problem is I don't know how to remove it. I assume I'd start by taking the nut off the bottom, but then what? I don't see anything above the bushings but it is dark out.
When I grab it I can wiggle it around a bit and hear the bushings creaking. The damn things are so long I guess I must have banged it on a rock at some point.
Is it just a standard bolt? If so what grade and thread type, etc do I need to look for?
Thank you much!
*Edit: I believe it is just the bolt that broke, its hard to tell from the picture but it leans slightly back toward the rear of the truck, so I asume I can just pull that one out and pop a new bolt through the bushings with no jacking? Just not sure how to access the top of the bolt.
Old 12-29-2007, 08:41 PM
hodgepodge79's Avatar
just get inside your rig and pull back the carpet in the general area of the body mount. There should be a plastic plug in the floor that you remove. Go down to your favorite bolt and screw store for a replacement.
Old 12-29-2007, 08:45 PM
Ok, great! It seemed that simple, just never worked on body mounts before, can't hurt to check with the YT crowd.
My only concern now is getting it out. I figure if it is broken somewhere between the bushings I can probably just pull it out from the top and let the bottom drop out.
Old 12-30-2007, 01:57 AM
isaac338's Avatar
may as well do a 1" body lift and poly bushings while you're there
Old 12-30-2007, 06:08 AM
waskillywabbit's Avatar
If it was "broken" it would fall out.
Body mounts go through the body floor and are in recessed holes covered by rubber/plastic tops. Simple hand tools and a jack you can remove them easily.
I would suggest new polyurethane body mount bushings (all that black rubber is long since dead) and a 1" body lift.
Old 12-30-2007, 06:31 AM
Well it's bent, maybe cracked. I realize if it were two separate pieces it'd fall out..
So, I do need a jack to just replace the bolt in the one?
I'll upgrade the bushings at some other time, when I can do them all.
Thanks.
Old 12-30-2007, 06:39 AM
Then remove the bolt and bushing and beat it into submission with a hammer and weld it solid again. It really doesn't look bent or cracked from that photo...or as if anything is wrong with it actually.
It might be "interesting" trying to wedge all that stuff back in there without loosening all the mounting bolts on that side.
Old 12-30-2007, 06:47 AM
Doh! I'm sorry about the confusion. I meant the bolt is cracked. The mount looks fine to me as well.
So I guess what I meant was, I can just slide old bolt out, new one in without jacking anything if I leave the bushings for now?
Old 12-30-2007, 08:24 AM
element's Avatar
I had a similar problem with an S-10 Blazer. The bolt actually rusted and stretched (not broken).
I think you probably need "Grade 8" for a body mount, but someone correct me if I'm wrong.
Old 12-30-2007, 08:27 AM
jason191918's Avatar
If it is just bent and not broke, may as well sawzall it off.
Old 12-30-2007, 09:22 AM
MMA_Alex's Avatar
not unless you're gunna use sae bolts...
not sure what the stock bolts are, but generally you're gunna want a higher grade bolt. generally coarse threads will hold better in vibrating applications.
Old 12-30-2007, 11:22 AM
Belize Off Road Team's Avatar
how hard is it to change all those bushings for new ones? no lift. and how much do new bushings cost?
Old 12-30-2007, 04:36 PM
Well thanks for your input guys. Was an extremely easy job.
I pulled the old one out in the store parking lot to make shopping easier. It took some twisting and prying, it was bent but not broke.
Ended up going SAE because all their metric stuff was too short, however I went from a metric 8.8 (SAE 5) to a SAE 8. Maybe on the weekend I will look into doing the rest just for the hell of it. It gives me something to do.
Old 12-30-2007, 04:48 PM
Jay351's Avatar
I payed over 80 bucks for one new bushing and the metal sleeve.
Old 12-30-2007, 09:51 PM
isaac338's Avatar
nice to have things uniform, too. i can't even begin to explain how much it aggravates me to have to go back to the toolbox and search for that rarely-used SAE socket because some wingnut changed out one bolt. at least this way you'll know to grab the SAE tools first ;D
Old 12-30-2007, 10:36 PM
Yeah, that's my main reason for wanting to convert them all to sae, I was hesitant to buy only one. But at least I know everythings in good shape again until I do the rest.
Old 12-31-2007, 06:45 AM
4Crawler's Avatar
Changing bushings is not hard, given no issues with getting the old bolts off:
- http://www.4crawler.com/4x4/CheapTri...shtml#Bushings
- http://www.4crawler.com/4x4/ForSale/...l#PolyBushings
09-04-2015 09:27 AM
Scotto6591
09-01-2015 03:24 PM
ViperTT
08-14-2015 05:27 AM
cgilley
07-25-2015 10:55 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: Broken Body Mount
