Brand new engine make "wrong" noise
Alright so this weekend i just threw in a brand new engine from Oregon engine builders. the "Superstock" 22re.
i ran it at around 2,000 rpm's for twenty minutes to break in the cam, changed the oil did all the proper break in stuff.
then i was revving the engine just a little bit and i noticed at about 5,000 rpms it sounded like the fan would rub for a quick minute. so i stopped and checked didn't find any evidence.
Then i drove the truck home about twenty minutes and upon getting almost home it started making the rubbing noise at idle and upon de-acceleration, at a steady throttle it doesn't make the noise noticably. at idle its really bad, it seems like its something thats catching maybe in the belts like one of the pulleys. i cut the a/c belt off thinking the pump was seized and that did nothing now i'm just minus a brand new belt.
the truck still runs great and has great power but does not sound good and its not just normal valve noise because it was purring like a kitten when first started.
please help!
91 toyota 4runner 22re SR5
please help!
Another ORE making noises? WHy does that no surprise me. Feel sorry for ya man.
Anyway, it's extremely hard to diagnose a noise without having some sort of video or audio, because anything would be a guess.
ya i'll try to put a video up tomorow but any idea's would be greatly appreciated. its wierd because it runs perfectly fine. it sounds like its outside of the engine, and at first guess i would say its the fan rubbing but its not cause i've checked that several times
oh wait, I think I kno what you might have done since at idle and decell noises is usually timing chain related or possibly a rod bearing.
Did you buy and entire engine or just a long block where you had to put the timing cover and stuff on? Because if you only got a short block, you might have put too long of a bolt in the middle of the cover (top oil pump bolt I believe) If a long bolt is used it will hit the timing chain. Since most of the slack in the chain is at idle and on decel it moves around in there enough to hit that long bolt.
Or one of your timing chain guides (most likely the drivers side) came loose.
it was a long block and yea i had to put the oil pump and timing cover on and all that stuff. i did have trouble getting the right bolts in the right place. which bolt do you think is wrong?
This might explain it better. I explained it wrong too, the long bolt interferes with the tensioner not the chain hitting the bolt.
If it is too long and you replace it with a shorter one and you still have the noise it is still possible you damaged the tensioner and it's causing the chain to hit against the guide rails too much.
I recently installed the timing chain cover and oil pump on my 1988 4runner, 22RE, 5 speed, so I feel you.
I hade the cover off and knew about the oil pump bolt issues so I installed them all and figured out their position before I installed the timing chain cover. I marked the position and the bolt in red.
You probably know this, but here is the hole you need to worry about. The timing chain tensioner is behind it and will be damaged if you use too long of a bolt. Also, this hole must be sealed or oil will leak out. I sealed mine with Ultragrey RTV, but the FSM talks about some special sealer that cures when the air is cut off which should happen when you but the bolt in place.
I learned this trick from a build here on Yotatech. I taped a blow up of the FSM bolt diagram to my timing chain box and used it to help keep the bolts in order--this is the only way to fly
[IMG]
http://farm5.static.flickr.com/4101/...d5d96ec8f0.jpg
[/IMG]
[IMG]
[/IMG]
timing chain tensioner at the very least. Guides if they got damaged by the chain. Highly doubt that though especially if you used a steel rail kit.
do you think i could get away with putting my old tensioner in there? the old engine only had 150,000 on it when the previous owner ran it out of oil and blew a rod.
I wouldn't. Forgot to mention the timing cover gaskets as well and possibly the oil pump o-ring. Meaning might as well just pick up another timing chain set. www.engnbldr.com
good luck. also with the motor in general. Those ORE toyota motors do not have a good rep. Someone with those superstock motors just had a major issue with theirs. Does yours have the Kieth Black pistons and oversized valves in it?
i believe the pistons are regular, but it has oversized valves. i've been reading mixed opinions about their motors and most of them seem to be very good.
2 or 3 complaints on here within a month or so, tells me something is up. I'd dig them up, but I am sure you can find them via the forums search. Most of the good reviews I have seen outside of here has been other make engines and not the Toyota ones.
Definately check the timing cover bolt first as XXX said. If that isn't your problem, you can pull the accessory belts to eliminate or isolate the problem from outside of the motor. If that doesn't narrow it down, you can pull a spark plug wire at a time to see if it is related to a particular cylinder.
Systematic checks are your friend.
And as XXX mentioned before, without a sound clip or video clip we are all just tossing pasta at the wall to see what sticks.
