brake upgrade for 5 lug pickup
I'll need new rotors and pads soon and was wondering if anybody had any cheap tricks to upgrade these brakes...?
Long shot but does the 4 piston 6lug calipers bolt up to a 5 lug spindle?
If not i guess i'll just settle for some $64 cross drilled rotors from rockauto and some nice ceramic pads.
Thanks,
Mike
Thanks,
Mike
I just did a mild upgrade on my base pickup from the 17s calipers to the F18Q calipers.The piston is a lil bigger and the rotors are a lot larger and thicker.I bought the rotors for $18 each new on ebay and the calipers and brackets for $28 from a pick and pull.then added a $20 new 1" bore master cylinder and she stops quick now.the longbed brake pads are about 1/2" wider than the base model pads. and 5 bucks cheaper lol
here you go
TOYOTA TRUCK
Pickup, Hi-Lux
95-91 T100 Pickup 4WD 1/2 Ton S13WB
95-89 2WD 4 Cyl. l 17S R/L
95-89 DRW AISIN 1 R/L
91-89 Long Bed F18Q R/L
91-8/83 2WD, 1/2 Ton AISIN
88-86 Long Bed 4WD W/4 Cyl. S12-8
85-80 Long Bed 4WD S12+8
The f18q are a lil larger than stock but are single pistion like stock dont know if you were wanting dual piston calipers or not but the 1/2" wider pad and taller wider rotors make for great stopping and great pedal feel.they are easy to come by off 89-91 dxl or longbed trucks.the 17s calipers i belive are what you want if you want 4 pistion calipers.the f18Q was just a cheap easy upgrade for me considering new rotors for stock were $35 and the guy on ebay had the f18q for $18 and should still have some
TOYOTA TRUCK
Pickup, Hi-Lux
06-01-2021 01:51 PM
Vargntucson
07-04-2015 12:15 PM
