Brake rotors pressed onto hub??? Sort of urgent
Old 07-13-2009, 05:16 PM
Matt16's Avatar
Exclamation Brake rotors pressed onto hub??? Sort of urgent
I've unbolted the 6 bolts holding the rotor to the hub... and its not budging. Any ideas? I need to drive the truck to work... any ideas would be greatly appreciated!
Old 07-13-2009, 05:19 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Cocoa cola classic, and a BFH. Sometimes can can be a nitemare to remove
Old 07-13-2009, 05:23 PM
94toy22re's Avatar
Did you remove the lock washers?
Old 07-13-2009, 05:39 PM
peapicker's Avatar
if
I am having a hard time picturing that particular assembley, If the wheel studs go through the rotor from the back of the hub try nockin them out to.
Old 07-13-2009, 05:56 PM
Matt16's Avatar
No, the rotor is bolted to the back of the hub with 6 14mm bolts.
Old 07-13-2009, 06:01 PM
Elton's Avatar
give it a tap with the bfh
Old 07-13-2009, 06:23 PM
Matt16's Avatar
Was it press fit to start with??? BMFH isn't working so far.
Old 07-13-2009, 06:32 PM
904_runner's Avatar
no its not a press fit.
just give it a good wack, a bunch of times, it will pop off.
Old 07-13-2009, 06:41 PM
Matt16's Avatar
Alright, gonna do my best Mike Tyson impression on my hub/ rotors... no wait, biting it won't help.
Old 07-13-2009, 07:00 PM
Knightfir3's Avatar
Hey Matt16 - I had to replace my rotors last year and I had a hard time getting them off until I realized they are locked on with those 6bolts AND the hubs. Here is a thread that solved my problems (steps 1-9) with pictures. To get them off, you just gotta take the hub dust plate and the caliper assembly. Should pop off right after that with little or no convincing (i.e. BFH).
https://www.yotatech.com/forums/f128...4runner-76360/
Hope this helps!
Old 07-13-2009, 07:15 PM
jason191918's Avatar
chisel, pb blaster, a 6 pack of red bull, and a bfh
Old 07-13-2009, 07:30 PM
Elton's Avatar
maybe a little heat from a torch ?
Old 07-14-2009, 01:50 AM
91 4Runner's Avatar
Once the 6 bolts are out of the rear stand it on its edge or put the rotor in a vice (Making sure to avoid marking the rotor) and pound a cold chisel in the gap between the two. Do this in a few spots around the outside - and watch your toes.
Old 07-14-2009, 01:51 AM
TNRabbit's Avatar
PB Blaster & torch helps. You have to beat the living crap out of it!
Old 07-14-2009, 03:03 AM
Matt16's Avatar
I used a chisel, a hammer and a crowbar and now they're off and its 4am. I don't think anyone has ever done any maintenance on this truck prior to me. Both calipers had two pots which were completely seized.
Old 07-14-2009, 04:41 AM
peapicker's Avatar
aaaaaaaaaaaa crap!
I had solid axle on the brain, not ifs! sorry.
Old 07-14-2009, 07:43 AM
Hophead's Avatar
Hey Matt how'd it go..??? did you do anything with the caliper pistons? Wanna help me do mine?
Old 07-14-2009, 08:15 AM
Matt16's Avatar
4 of 8 of my caliper pistons were totality seized, I had to replace both calipers. Bleeding the brakes is the toughest part of the job. A chisel, crowbar, hammer and bench vice takes care of the rotor/ hub assy.
Off to bleed my brakes- I hate that job.
glowz825
01-25-2022 09:28 AM
jasonty
41
12-23-2018 01:00 PM
Steven.m.paulk
07-24-2015 01:44 PM
PlayAwhile
07-20-2015 11:36 AM
Steven.m.paulk
07-13-2015 01:40 PM
Quick Reply: Brake rotors pressed onto hub??? Sort of urgent
