Brake Rotor Replacement Question
I'm replacing the front brake rotors on my 91 4runner 4WD.
Was thinking of using Blue Loctite (the non-permanent kind) on the rotor retaining bolts.
Anyone know if this is either a good or bad idea?
thanks
thanks
It probably wouldn't hurt. But I ain't too sure it would help either. I'm guessing the brake rotor/hubs might get to hot for that stuff to hold good. I use heat to break that stuff alot, and it don't take much.
It's not required.
How many have you heard have come loose when torqued correctly ?
Fred
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
