Brake m/c swap, need help!!
Old 08-27-2011, 10:42 AM
alyota4x4's Avatar
Exclamation Brake m/c swap, need help!!
well im swapping out my stock m/c for a 1" bore, and the original has a sensor on the cap. the one im trying to swap has a plug in the m/c itself and it doesn't fit. what is this sensor for? and what can i do about this, can you just not run it? what have you guys fone? thanks
__________________
Old 08-27-2011, 11:30 AM
skypilot's Avatar
its for a low fluid level idiot light on the dash.
I would leave it off and just tape the pigtail up so as not to be butchered. Or you could just get the pigtail off the donor truck and splice that in.
Good luck with your swap!
Old 08-27-2011, 11:37 AM
alyota4x4's Avatar
thats what i thought it was for,thanks skypilot,but if i leave it unplugged is that going to make the light stay on? if so i may just cut it and hard wire it.
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
fountain
12-31-2015 06:08 AM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Brake m/c swap, need help!!
