brake load sensor bypass
Old 05-22-2006, 07:04 AM
Hammerhead06's Avatar
can anyone give me a link or detailed instructions on bypassing the load sensor in the rear of an 88 yota pick up? hammerheads06@yahoo.com
Old 05-22-2006, 07:38 AM
snap-on's Avatar
depending on how your rear breaks are setup it may not be adviseable. before i swaped axles in my truck i had virtually no rear breaking. i simply disconeected the arm from the axle and screwed it up onto the bottom of the bed. that provided the right amount of ballance i felt. but when i swiched axles the breaks actually worked in on this one and it locks up to easly with no load in the rear.
Old 05-22-2006, 04:35 PM
well heres the deal, i bought a pick up(very beat up) and have built it into quite a machine but when i bought it it wasn't hokked up (lpvs) so now to make my rear brakes work i want to just bypass it, so thats it in a nutshell, i really need to do this soon
Old 05-22-2006, 06:10 PM
Rather Diesel's Avatar
You can just run a single line to the rear, and get a manual prop valve, and adjust as needed. Mine was rusted solid, so I trashed it. If you add a hydraulic ball-valve, you can trash all that parking brake crap also. Then, just step on the brakes and turn the handle 1/4 turn for a parking brake.
HTH
Roy
the1998sr5
15
07-14-2020 08:35 PM
chuckross1957
06-28-2019 10:19 PM
montanatruck
02-26-2017 07:07 AM
nonstop
07-24-2015 06:29 PM
CanRunner
07-20-2015 01:29 PM
Quick Reply: brake load sensor bypass
