Brake Lights
Old 01-25-2015, 07:09 AM
Unsurpassed's Avatar
Brake Lights
I'm new to this sight and also owning a Toyota. I bought a 1992 Toyota Tacoma Sr5 3.0 V6 4WD automatic. Original motor. Truck has 133,000 miles. My concern is my break lights don't work. Fuse is fine. Headlights also don't work on bright. Would greatly appreciate any advice. Thanks
Old 01-25-2015, 07:25 AM
bswarm's Avatar
Check the brake light switch, it's on the brake pedal linkage & has two wires going into it. High beams could be the headlamp switch or relay.
Old 01-25-2015, 09:02 AM
Ok. I'll try that. Thanks a ton.
Old 01-25-2015, 11:24 AM
wyoming9's Avatar
Red face
Curious to see a 1992 Tacoma??
Old 01-26-2015, 07:31 PM
RAD4Runner's Avatar
You could start by finding a schematic of your truck and posting it so others can help. I have a first-gen 4Runner, but can if I'm looking at schematic for 1992 truck.
Then, Got multi-meter?
How do you know that fuse is fine?
Both High Beams do not work?
Does flash work? If it does, it's most likely the high beam contacts on your dimer-combo switch (stalk).
Again, Got multi-meter?
Old 01-26-2015, 07:56 PM
rworegon's Avatar
The Tacoma first came out as a 95.5 model year and never with the 3.0 V6 as the original engine.
So....not likely you have a 92 Tacoma as least here in the USA.
ashersullivan88yota
01-18-2022 05:37 PM
fountain
12-31-2015 06:08 AM
09-04-2015 09:27 AM
Sandman
07-14-2015 12:36 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Brake Lights
