| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Brake Diagnostic's, please
__________________
1993 T4R 3.0L V6 W56 4.56's SAS In Progress With '84 Front Axle, 4.88's |
#2 (permalink) |
sounds like a vacume problem with the brake booster
__________________
JP 2003 Tacoma White TRD E-Locker, 3" toytec lift, 2" RB BL 10,500 milemarker, 32/12.50 BFG MT on black wheels UWS black toolbox, and working on more. 2007 fj cruser (moms) 86 4runner 22re auto 3" leafs 32bfg mts |
#3 (permalink) |
going to be your master cylinder, had it happen on my old 86 a couple of times. very disconcerting when you step on the brake pedal and it goes to the floor.
check around for a supplier that may have a lifetime warranty because it will go out on you again. some folks recommend using a block of wood under the brake pedal to prevent damaging the seal by pumping the pedal all the way to the floor. good luck, keep us posted. lee
__________________
93 sr5 v6 auto, 4x4 Photos http://s866.photobucket.com/albums/a...albumview=grid there are quite some attractive ladies on here with Toys. (compliments of ironmike) ifsc 3(.0) http://tlca.org www.of4wd.com www.sontt.com |
#4 (permalink) |
Brake booster or master cylinder are bad, I go with the brake booster first.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#5 (permalink) |
#6 (permalink) |
Super Moderator-Sponsoring Member
Staff
If you are unsure of which is bad take it in for a diagnosis by a mechanic. You might want to replace both as it is scary not to have brakes.
Please update when you find out the answer to your problem.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. |
#7 (permalink) |
The fact he had brakes then all of the sudden didnt, I aint perfect Fred bit replacing both at the same time is a smart move anyways.
__________________
#8 (permalink) | |
Quote:
The vacuum boost (brake booster) is the "power" park of power brakes. Bad booster = very, very hard brake pedal, not a brake pedal that drops to the floor. I do fully agree, that if the poster is not familar with the brake system, then take it in and have someone check it out and fix it. Sounds to me like the master is taking a walk on the wild side. Also Toyota does something really funky with the PS system and the ABS system, though that should affect or cause the pedal to go to the floor. ![]() Fred Last edited by FredTJ; 04-28-2007 at 07:07 PM. |
#9 (permalink) |
Did you have normal pressure, then all of a sudden the pedal went to the floor? If so, I would suspect a sticking caliper piston. It was probably stuck, then midway through your braking, it popped free. Thus losing pedal pressure. Mine does the same every once in a while.
One way to check your pistons: Remove your calipers and take out the pads. You should be able to compress each piston with a set of channel locks (easily). If one is exceptionally hard to compress, it is likely the cause of your problem.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k) Last edited by ChickenLover; 04-28-2007 at 07:14 PM. |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) |
I do not believe it has to do with vacuum pressure. If the brake booster is bad, like FredTJ said, it would cause and extremely hard pedal, not a soft one. Any leak in that part of the system wouldn't do that. The master cylinder seems to me like to be most likely the problem. I know it's a two chamber system, however, it would seem like both chamber seals would have to be bad, BUT, I do have full pressure at some stops. ChickenLover's theory could be true, but it is not a "full pressure then loss of pressure." It is one or the other. Any more feedback? I appreciate your thoughts so far, it has helped a great deal. Thanks in advance.
__________________
#12 (permalink) |
When's the last time you did a brake job? I'd replace the m/c, booster, calipers, pads, hoses, etc...money well spent in my book.
#13 (permalink) |
id say the mc is going bad
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust 120amp Mr. Alternator rear lockrite, optima yellow top xrc8 winch & AOR bumper coming soon my bikes: 1980 Honda CX500-1997 honda cbr F3 |
#14 (permalink) |
I had a similar problem and it ended up being worn pads combined with a stuck caliper. The pedal would go almost to the floor if I didn't pump in once before I braked.
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#15 (permalink) |
Leave the brake lines connected to the M.C. and unbolt it from the booster. Look for any sign of brake fluid around the seals, if there is get a new master cyl. as rebuilds tend to be junk. There may also be brake fluid residue on the booster below the master cylinder.
On another thread a guy had a problem with swelling brake hoses causing the same condition, so I would look at those as well. |
#16 (permalink) |
not to say this is the cause, but yesterday when workin on a friends Buick Park Avenue which had no brakes we went and got a nice old master cyl from the scrap yard bolted it on and started to bleed it when we then found a line now that had a pin hole and was sucking air in. with the old master cylinder on i guess there was air in the line and wasnt making this line under pressure and the new one made it, anyways, it was now pissing brake fluid out this leak where before it wasnt. old master cylinder put back on now works fine and makes this line piss fluid before.
was similar to brakes would go to the floor, could get them to lock up back tires but not the fronts, but wasnt losing any fluids at all. replaced front line, and now everythings ok. try bleeding the system from brake lines and not the bleeders. it should shoot out pretty good if theres on thats weak look for symptom there. also if it is m/c you might want to change the booster as im not sure if the yotas will but some vehicles will suck the brake fluid into the booster. jeff |
#17 (permalink) |
Found the source...
![]() The grommet's in there are bad, and is letting air come in. Its either buy a new master (which isn't a bad idea, going on 250k+ miles) or pay $10 a piece (there's two in there) at the stealership. Wow, what a rip! Thanks for the input guys!
__________________
#18 (permalink) |
Doctor, you got latex gloves on? Cool!
__________________
90 4R SR5 4WD 5SPD 3VZE 211K miles '69 Ford Mustang Mach I '82 Suzuki GS1100E '68 Chevelle SS396 '99 1/2 Pathfinder LE |
#19 (permalink) |
totally needed. lol.
side note, i want ur 69 stang. lol. ok. im done.
__________________
Dead '94 2.4L 22re 2wd pu, k&n air filter, thrush glasspack, 4in over stock rear shackles, 1.5in ball joint spacers, 4in infinity reference dash speakers, pioneer head unit, 10in p2 sub, alpine amp. bed cap topper thingy. great for campin. Current-2004 toyota tacoma, 2wd, 3.4L, prerunner, e-locker, tow package, trd package, ext cab, alpine head unit, polk speakers all around, punch p2 10" run off a alpine mono amp, silver paint. ohhhh its purty... |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front E-brake cable installed, but no brake response | bad_brains | 86-95 Trucks & 4Runners | 3 | 02-13-2007 07:08 AM |
| All Pro Rear Disc Brake Kit removes parking brake! | RunnerUp | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 09-28-2006 01:26 PM |
| Install brake controller looking for cold brake wire..94 4Runner | arielb1 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 10-09-2005 02:18 PM |
| 03 Brake question for all you brake experts | The Dutch Man | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 06-26-2004 10:47 AM |
