Brake booster question
Old 01-30-2015, 06:03 AM
JusToyotAdkins's Avatar
Every time I shut off the truck I hear a hissing noise coming from the booster. So I figured it had leak in it and went and bought a new one but it's still hissing. And the truck dies whenever I hit the brakes. Any suggestions??
Old 01-30-2015, 06:19 AM
bswarm's Avatar
Replace the check valve on the end of the hose where it plugs into the booster.
Old 01-30-2015, 07:26 AM
AZkid's Avatar
x2
Old 01-30-2015, 07:56 AM
scope103's Avatar
http://www.toyotapartsoverstock.com/...rimLevel=18292
There's a different part depending on 22re/3VZE (see why you list your engine type when asking a question?), so use your VIN to assure you get the right part.
Old 01-30-2015, 08:18 AM
Sorry about that. It's on a 22r
Old 01-30-2015, 08:23 AM
And btw can I use the universal one from oreillys?
Old 01-30-2015, 08:39 AM
scope103's Avatar
You mean, Dorman 80189? It doesn't look like it will fit.
Old 01-30-2015, 09:00 AM
47149 is the one I'm talking about
Old 01-30-2015, 10:36 AM
scope103's Avatar
That DEFINITELY looks like it won't fit (1/8" x 1/4" http://www.dormanproducts.com/itemde...8&SEName=47149). But go ahead and measure the line yourself.
I think that Dorman check valve might work for very-low flow applications like the PAIR or ADD. I can't imagine it carrying enough flow to actually work the brakes.
Old 01-30-2015, 10:42 AM
bswarm's Avatar
You need a brake booster check valve, not an emissions control check valve which is what the above post is linked to.
Old 02-03-2015, 04:45 PM
Took a valve off my 2wd to see if it would fix it. And still dies when I brake
fountain
12-31-2015 06:08 AM
CanRunner
07-20-2015 01:29 PM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Brake booster question
