bought a used tranny
Old 03-14-2008, 07:29 PM
jdw1's Avatar
i bought a used tranny with 120,000 miles on it. no leaks anywhere, no play in the input shaft, or in the flanges where the driveshafts connect to. but, when i put it in gear and turn the input shaft or flanges, its kinda noisy. is this bad? i paid $400 for the tranny, transfer case, and front and rear driveshafts. checked the tranny oil it was clean and fine. checked the transfer case oil which was low. any opinions? is this noise im hearing a bad thing? maybe the bearings are dried from the tranny setting up for a while?
Old 03-14-2008, 07:49 PM
87toy.'s Avatar
what kinda tranny is it? and it should make some noise, lots of moving gear on gear action. as long as there are no clunks or clings etc or when you turn it or hard spots it should be fine.
Old 03-14-2008, 07:50 PM
Staff
DeathCougar's Avatar
With no oil in it, it should make a little noise. It will go away once you get some lube in there.
Old 03-14-2008, 07:56 PM
jdw1's Avatar
its an original toyota tranny, original miles
montanatruck
02-26-2017 07:07 AM
WellsR
12
07-31-2015 03:27 PM
yourrealdad
07-21-2015 11:13 AM
Iceman4193
07-15-2015 04:48 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: bought a used tranny
