Body Lift Shifter Woes
1 Post
I did my body lift this weekend, and I'm very pleased with it, I love it, the only problem I have is my shifters, My transfercase shifter is literally bent into an L so it will clear the gear shifter when it goes into 4-low, not to mention it hits me in the dang leg, so lets see pictures of your shifters if you've got a body lift, Also if anyone has an extra transfercase shifter and gear shifter I would buy them, so pm me.. thanks guys, I gotta figure this out.. its pissing me off.
I have 2 of these for my t-case shifters: http://www.4crawler.com/4x4/ForSale/...wShifter.shtml
Hmm, thats odd. I would go get some 3" long chunks of cold rolled steel and use those as extensions. In the PA instructions you need to graft them in at the bottom of the shifter. Doing this made mine clear almost everything.
I just had to bend my shifter, up and to the left a little to clear the t-case shifter. Been that way for over a year and no problems at all...
The problem with the screw on ones from 4crawler is where they are attached. To the top of the shifter. You need to weld in the extensions at the bottom, BEFORE the shifter bends. This will clear the floor.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
