Body lift question
Body lift question
Im in the process of installing a body lift on my 93 pickup.
I wondered if it was a problem that the cab was just slightly forward. I pushed and lifted it and pushed some more but couldn't get it to slide back just slightly like maybe a centimeter...any ideas? Unless you don't think it will be a problem. Maybe I'm just being a perfectionist, lol.
Here are some pics of the front two mounts (the ones just behind the front bumper) so you can see what I mean :
Drivers side
Passenger side <br/>
Drivers side
the rest were passable. i honestly was just trying to get it done by this point cause i needed done in time to drive to work. i was kinda bummed the kit didn't come with new ones (got the 4crawler 2" kit)
How much work was the installation vs the gain from 2" of lift? I'm thinking of going a little bigger for tires but I don't really want to alter the IFS because the truck is 90% daily driver. Did you have any problem with things like wiring and controls that go from the cab to the frame?
I had no problems with 2" - 4crawler off road says 2" is the most before you start having to do mods. He has an amazing write up that I used the whole way through it so I would check it out for sure. he gave me an adapter bracket for the front bumper and radiator, but i didn't even need the radiator one. Ill probably put it on soon anyway just so that i can get max efficiency from the fan though - i had to remove the lower portion of the fan shroud. I also plan to get the drive shaft 1" extension but i could get away without it TBH.
Always replace those UV-wasted rubber bits!
But fyi: 235s fit without any mods. 31s will fit now with your 2" blocks.
Hugh_Mann
12-22-2015 05:27 PM
drk421
11-20-2015 09:40 PM
WTB[PacNorWest]: WTB - 1999 4runner Driver's Side Running Board End Caps
Finelygotone
11-18-2015 08:35 AM
Whitemoneypit
20
11-01-2015 10:20 AM
