Body Lift
Body Lift
hey guys,
looking at doing a 3in body lift after x-mas. got a few questions. first- does anything need to be lengthened, or adjusted? does a body lift this big come with any problems? also does anyone have some pics of there 4runner on 31's with a 3in BL..
thanks in advance guys
if you search body lifts youll find everything you need but it all depends. when your lifting it youll find out as you go along. the 3 main areas are steering, gas tank and your shifter they will all be affected when you do a body lift. how much you will have to replace will depend on the height of the lift. a 3inch you may get by on all of that.
31" tires on stock wheels will look a little goofy, run a 32x11.50 or somthing, that would fill the wheel well out more and make it look better
I had to extend:
Steering colum - came with spacer
shifters - came with spacers that you cut + weld in
My fuel filler neck leaks a few drops when I fill up, I have to eventually fix that.
My intake had to be "modded" to work, but I ended up doing the ISR mod anyways.
All brackets to drop the rad, grounds and whatnot came with the kit, aswell as the front bumper brackets.
I had to extend:
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
