| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
I've had a 12 volt (Thomas) compressor and it has worked flawlessly for the last 10 years:
http://www.4crawler.com/4x4/CheapTri...BoardAir.shtml It'll put out 2.2 CFM and has a 100% duty cycle (make sure you get a high duty cycle unit). One trip I had to use my compressor to air up a total of 6 trucks before heading home. We planned to hit a remote gas station 50 miles from the next town, but when we got their, found their big compressor had broken down early that day. Took 45-50 minutes of constant running, but the compressor and motor did that without a problem.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 08-13-2008 at 02:49 PM. |
#3 (permalink) |
Did you run a reserve tank as well or did you just have it hooked up to a switch so you could turn it off and on?
#4 (permalink) |
[hijack] 4crawler can I just drop off my rig to you and a blank check and have you build it for me? I love your site but it breaks my heart to see how far I've still got to go. [/hijack]
__________________
RB4R Life Member. 1989 SR5 4runner. Tread Wright 31/10.50/15's. 4.56 thirds, an Aussie in the @$$, Budbuilt plate, Marlin Crawler front, modified MC rear, Supra MAF conversion, ZUK coils in the rear and 4crawler BJ's in the front, LCE header. |
#5 (permalink) | |
Quote:
Yes: - http://www.4crawler.com/4x4/CheapTri....shtml#Storage and yes: - http://www.4crawler.com/4x4/CheapTri...r.shtml#Wiring
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#6 (permalink) |
There are alternatives to Powertank that are MUCH cheaper. I got a basic CO2 set up: 20lb Tank, reg, hoses, and fittings, for 50 bucks. If you don't have a source for a free tank (beverage canisters from a restaurant) you'd be looking at 100-150 for a full set up.
However, looks like you are looking specifically for a VIAIR set up, so I'll stop there. Just wanted to point out the alternatives.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#7 (permalink) |
I'll be setting up my mobile air system here soon in my 91 PU using the setup your talking about with a Vair compressor and probably a 5gl tank or maybe a little larger. I cleared out my toolbox and mounted a second battery, so running the power will be very easy...
![]() or coarse all the crap to the left in the box will be gone, but you get the idea of how easy wiring will be with having a battery right there by the compressor... just an idea if you haven't thought about that already
__________________
91 PU, 4wd, manual, 22re, .30-over, engnbldr RV head and 261 cam, MC 1200lbs clutch, misc LCE, engnbldr, and MC parts and HW, Pacesetter header and exhaust kit, Rancho UCA's , 4Crawler 1" diff and sway bar drop and 1.5" BJ spacers, WabFab 3.5" shackles, 31x10.5 pavement-pounding ATs on ProComp Extreme Alloys, misc SR5 interior goodies swapped in, 1000watt stereo system MySpace |
#8 (permalink) |
i already got my tank from a old air compressor.... i also have one of those big like 5 foot call co2 beverage tanks in my garage.... i wonder how many tires that could fill!!
i was thinking about going with the stock toyota a.c compressor but ill prolly go with this guy in canada that sells winches and stuff..his prooducts and service TOP NOTCH! http://www.freewebs.com/titanwinches/home.htm
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ |
#9 (permalink) |
I'll have to look into the beverage canister, does it already come with a regulator? Oh yea, and I don't have any hookups to get one so where can I buy one. If I can do CO2 for $150 then I would.
#10 (permalink) |
With CO2, don't forget to factor in the cost of the gas in your area. Going to be in the $10-$20 range per fill-up on your tank.
__________________
#11 (permalink) | |
Quote:
Very true.
__________________
#12 (permalink) |
I think I will mount the 5 gallon tank on the spare tire crossmember (tire is long gone) and then mount a viair 380 compressor in the engine compartment. Should work out well and provide plenty of oomph for tires or air tools.
#13 (permalink) | |
Quote:
My suggestion would be to get the pump and tank as close together as possible, maybe under the truck with the tank ( probably not a very good location though, unless you're a mall crawler and your using it for air horns ), or maybe just between a wheel hump and the front of the bed; could even make a nice little diamond plate cover for it mounted there too. Not only makes hose routing easier, but minimizes possible hose failure points as well...
__________________
#14 (permalink) |
You are probably right. I was thinking of mounting it in the engine bay to keep it out of the elements, but there is also a nice place on the inner side of the left frame rail that it might fit nicely. It will be easier to run some wires to the engine compartment then running 1/2" airline from the engine to the tank in the rear end.
#15 (permalink) | |
Quote:
__________________
#16 (permalink) |
I have an ultimate air tank....its basically a powertank "knockoff" but the quality is top notch. Highly recommended.....cheaper than a powertank
http://www.ultimate-air.com/ What you are looking for is high CFM numbers....If you can't run air tools or re-seat a bead the air is pretty much worthless (to me anyways) I love the flow rate on the co2 bottle and the portability...but it sucks when you run out on the trail....plus you gotta take it and PAY for air (which I dont really like) Overall, it is a great product...same quality as a PT but cheaper I am looking into a secondary back up air (maybe a viair compressor) for emergencies.
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#17 (permalink) |
Go to your local gas supply and see what they have in the way of CO2 tanks. Mine had a used 20lb aluminum tank with a used regulator for about $100. Steel tanks are cheaper but weight more.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#18 (permalink) |
If I run a viair 380 into a 3 or 5 gallon tank using a 165/200psi pressure switch, do I need to run a regulator? I have the option of using different pressure switches such as a 110/145 or a 145/175. Since the 380 is rated for 200 psi that is what switch I was going to run but I would rather not have to buy a regulator. What is the reccomended pressure for filling tires and running air tools? Thanks.
#19 (permalink) |
For tires, you can use any pressure, just go by the pressure in the tire. For air tools, they usually like 90-100 psi. You could get a low cost pressure regulator if needed.
I can swap out pressure switches in my setup pretty easy. I used to run an 85-100 psi switch and now I use 55-70 psi.
__________________
#20 (permalink) |
I have been looking for a "low cost" pressure regulator with a guage on it but haven't been able to find one. Could you refer me to one please.
#21 (permalink) |
4 crawler, I have been looking at how you wired your setup. My question is, why do you have a toggle switch (under the hood) as well as a pressure switch? My thinking is the only reason to have a toggle is if your system leaked so you could turn your compressor off so that it doesnt keep kicking on. Why not just run a pressure switch? I am just curious.
#22 (permalink) | |
Quote:
__________________
#23 (permalink) | |
Quote:
#24 (permalink) |
If you had no leaks, then yes the compressor would not cycle, but that is a big IF. Also, if you ever wanted to work on the system you would need some way to shut it off, suppose you could pull the fuse or disconnect the wires, but a switch is so easy and inexpensive to add.
__________________
#25 (permalink) |
Good point, I think I will add a on-off just to make life easier. On a side note, I have set a few trucks up with air suspension. If loctite thread sealant is used on the fittings, and they are good and tight, there shouldn't be any leaks. On another side note, what kind of relay are you running? You are running power from the battery and power to the pressure switch, off the same connection on the relay?
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| on board air | toyotaordie | General Vehicle Related Topics (Non Year Related) | 10 | 07-17-2007 12:48 PM |
| On board air? | bluedoyle | Offroad Tech | 7 | 11-28-2006 05:35 AM |
| On-Board Air | kev93p-up | Offroad Tech | 2 | 12-28-2005 10:00 PM |
| Air tank for on board air | mtnbkr | Offroad Tech | 2 | 05-05-2004 06:42 PM |
| On board air | seafarinman | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 11-11-2002 07:14 PM |
