Blue wire w/ a white line, stock stereo.
Does the blue wire with a white line in the factory stereo loom go to an optional power antenna? It's just sitting back there in the loom not connected to anything and I want to use it for something. I know it's an off the wall question but thanks.
Oh this is on my 86 SR5 pickup.
I believe it's the remote 'control' wire for amps, power antenna, etc.
If so, it will not supply enough current on it's own to power a CB. It can however trigger a relay to supply power to other equipment... but are you sure you want the CB on only when the radio is on?
When you get your test light, find the wire to the radio that goes hot when you turn the key on.
make sure the radio is off though so you don't accidentally get that remote wire or some voltage from a speaker wire.
Also, you could tap into the wire to the cigarette lighter.
dont grab power for your clovk...i think that only hot in the ignition position. That will drain your battery faster if not running.
Use the green wire going to your deck. DO NOT try to use that blue wire to power your CB. Bad things will happen.
Use a relay if you want it that way available at any stereo/alarm shop.
Wire 85 to the blue wire on your deck
86 to ground
30 to your cb
85 to a good power source...battery feed is fine.
dont use 87a
86 to ground
30 to your cb
dont use 87a
86 to ground
30 to your cb
dont use 87a
86 to ground
30 to your cb
dont use 87a
Kind of defeats the purpose of a 'switched' source, no?
Since if you wire 85 to the blue wire and a power source all the amps and stuff will be on all the time.
maybe you meant:
30 to a fused power source (battery)
87 to the CB
87a to anything that should be on when the blue wire is not hot
85 to ground
86 to the blue wire (hot when on)
87 to the CB
85 to ground
OOOppppssss.....glad you caught that for this guy.
86 to ground
30 to your cb
87 to a good power source...battery feed is fine...and yes fused is best. 15 amp should be good
86 to ground
30 to your cb
yeah...
85 and 86 are interchangeable, as long as one is ground and the other goes hot to turn the relay on
30 and 87 are interchangeable as well but typically 30 get's the voltage and 87 is the device to be turned on or off.
87a is the opposite of 87- if 87 gets voltage, 87a does not, and if 87 does not get voltage, 87a does, which is why 30 gets connected to the voltage supply (battery)
30 is the supply to 87 and 87a... which one (87 or 87a) gets voltage depends on whether the relay is turned on or off.
yeah...
I would just add to anyone reading this later that remember that at rest.....coil not energized.....30 and 87a have continuity, When coil is energized 30 and 87 have continuity. Coil is enegized by putting power to 85 or 86 and grounding the other(85 or 86....if powered 85 ground 86, .....if powered 86, ground 85)
common electrical wiring standards requires:
...30 to be connected to a constant (fused) voltage supply
...85 to be connected to ground.
standards also require 86 to receive voltage in order to turn the relay on.
therefore
... if 86 has no voltage, 87a has voltage and 87 does not
... if 86 has voltage, 87 has voltage and 87a does not
just for the phobic people... you knew there was a reason those relay and switch terminals had numbers on them....
therefore
zytra
01-24-2019 03:16 PM
Scotttekoch
09-28-2015 10:30 PM
