| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Blown Headgasket- It CAN happen to you
__________________
1994 Toyota 4Runner SR5 4X4 213,000 miles and counting 3.0 V6, 5 speed 10/15 MPG city/hwy(with 33's) Current Mods Headers, 2.5" Flowmaster custom exhaust, K&N FIPK KC Daylighter 100 Watt lights Ranchos x4, 2" Lift Downey coils 33-12.50 M/T's, 1" t-bar lift, 1" body lift Tow pkg w/ lighthookups Silverstar Headlights, Pioneer Deck w/XM Brushguard 250Watt JLAudio 8" W3 Sub Future Mods
12V Aux outlet-400/800peak inverter roof basket/lights Air locker 4.88 gears H.O. Alternator |
#2 (permalink) |
Wow, that suck man. Were you easy on her?
Im trying to keep mine from blowing, i never go over 2500, except when in 5th. Good thing you have a vehical to drive while its down.
__________________
94 4runner / SR5 / 3vz-e / 5spd / 4x4 (duh) / Mudcat EXT 30x 9.5R15s / Marlin Crawler HD Clutch / ISR / Hella 700FFs 100w bulbs / 2 10'' JBL subs / ported sub box / kicker mono amp / Pioneer DEH-P490IB / sitting 1-1.5'' below factory, thanks butt sag... |
#3 (permalink) |
I was easy on her. At least I think so. I never met the rev limiter, but I have to drive on hills, so keeping it under 2500 isn't practical for me. I rarely ever go above 4000.
__________________
#4 (permalink) |
Psht. Newbs. Shoulda bought a 22re
![]() kinda. I like me some 5K rpm in muh 22res
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS |
#5 (permalink) |
I redline my 22re 1st through 3rd everyday. Still get 22mpg. But I bought my 4runner with a blown gead gasket so hopefully it wont happen to me. lol
__________________
1982 2wd Pickup - Custom Interior - Pioneer 8" subs 1990 4runner - Blown Head Gasket Mod (fixed!) - Cruiser Coils - BJ Spacers - Bed Lined Fenders - CB/PA - Alpine HU - H4 Headlights - 2 15s and a Rockford amp. 1996 Camry - 400,000 miles on original engine/transmission. HELL YES!!! All it takes is a quart of oil with every tank of gas. Project: scratch building a modernized Lotus 7 replica using a 22-re Celica drivetrain |
#6 (permalink) | |
Quote:
70mph = 3k, but i never go over that, only if i have to.
__________________
#7 (permalink) |
The 3vz-e is known for blowing head gaskets. There was even a free dealer replacement offered a while back. I already blew two, but I tend to use the gas pedal more like an on-off switch.
#8 (permalink) |
22re or 3vze?
#9 (permalink) |
3vze. The recall has been done. This one's on me.
__________________
#10 (permalink) |
I drove mine like it was rented (5k rpm all the time) for over 120,000 miles (on top of the 92k it had on it when I bought it in 2000) & never had an issue UNTIL I overheated it. It ran great during that time.
After I had the dealer install a timing belt back in 2003, it never ran the same again...
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#11 (permalink) |
So I joined the blown head gasket club last week and I need some expert advice. I built the engine (3vze) about 2 years and 15,000 miles ago. The heads had to have a bunch of metal shaved off to get them back true and smooth, so the compression in each cylinder is now up around 170 psi. I'm thinking that this is what caused the gasket to blow. So, I need to find out if anyone makes a reinforced head gasket for the 3vze engine that can handle the higher compression. Any suggestions? Thanks.
#12 (permalink) |
I usually just throw metal head gaskets on whenever I di a HG job. Kind of hard to blow those
![]() In all seriousness though, my 83 22R-E (Yes, early EFI motor. Was in a Celica) blew the head gasket with about 300k km on it (180k mi). The head bolt stretched.
__________________
86 SR5 Turbo pickup Fiberglass bed, Fiberglass Fenders. 91 1.5JZ GT40 Supra. 77 Celica Liftback. (WTB: 20R Carb!) |
#13 (permalink) | |
Quote:
__________________
Aka Dirty Dude thanks to a4runnerfreak. '94 Toyota PU-2WD, 22RE, 211,000 & counting. I have some Fords too. Looking for a turbo 4Runner or FJ55. |
#14 (permalink) | |
Quote:
You want Multi-Layer Steel (MLS) head gaskets, but that will require special surfacing of the heads & block...
__________________
#15 (permalink) |
Aww man!! Thats lame..
damn v6, can't take an overheating I have had great luck so far, I keep everything in terms of cooling and lubrication in tip top shape. She sees 5,000rpm+ weekly and asks for more *knock on wood!*
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#16 (permalink) |
Bad temp gauge
That would drive me nuts not knowing whats going on under there
__________________
. . . I said lie, for me lying under a process tree . . . . |
#17 (permalink) |
Well...... its not like we had very accurate temp gauges in the first place.....
__________________
#18 (permalink) |
Thats right but i can see when its overheating and kill it.
__________________
#19 (permalink) |
in a hurry but the Head gasket set for Toyota 2.4L, 22R engine wont work for the 22re (both are 88-89) flame me for not searching the fourms i've been doing that all night with everything else i jsut found a cheaper place to buy my parts from mizumoauto.com
#20 (permalink) |
i meant will it work for the 22re sorry 200 or less for parts and the head job and new timing chain work around 150 at a local old school shop
#21 (permalink) |
i must be going through withdraws i miss my truck to much seeing it sit there, cant even think straight all i had to do was google and search I NEED MY TRUCK!!!!!!!!!!!!!
#22 (permalink) |
stormin, i cant believe it actually gave up the ghost. i thought urs was gonna be one to have no problems... oh well cant win em all. so what u gonna do with it? rebuild the 3.0? or swap in a 3.4....
![]() and rover, are you trying to spam or something? 3 posts within half an hour....
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#23 (permalink) |
Yeah, you're right TNRabbit. I got my lines crossed in my manual and saw the 142psi minimum as the standard. With the compression in the good cylinders basically normal, what's my most logical conclusion? This is now the 3rd HG to blow on this engine...the original, the recall, and now this one. What could cause chronic HG problems?
#24 (permalink) |
Yeah, It sucks, but at least it didn't leave me stranded somewhere. I'm having the headgasket done as we speak. It shouldn't need a rebuild, and I'm lacking the funds to do a swap.
__________________
#25 (permalink) |
Along the lines of head gaskets. Anyone changed one then during the inital run up blew it out!? yeah happened to me tonight. Also happened on my 22rte but that was because I followed haynes manual for the part of putting sealent on the block. Most retarded step I have ever seen in a manual.
I know the causes of head gaskets going on the 22re, bolts stretch, over heat. but seriously with all new parts! never even heard of a hg blowing so fast!
__________________
evo, turbo 4runner, f150, cobra, n/a 4runner, 69 stang. "I am not a slacker, I am a deligater." |
| Tags |
| 87, blow, blown, copper, drive, exhaust, gasket, happen, head, hs9728pt1, mls, pick, pickup, price, rtv, sealing, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bad things happen in three. 22R headgasket. | yotaduck | 86-95 Trucks & 4Runners | 27 | 03-28-2009 09:03 PM |
| possible blown headgasket? | Kyle95sr5 | 86-95 Trucks & 4Runners | 9 | 10-04-2006 07:31 PM |
| Another blown Headgasket!! | Yamaha+Toyota=Fun | 86-95 Trucks & 4Runners | 19 | 01-29-2006 07:42 AM |
| I think my 00 has blown it's headgasket | kenandjenn | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-21-2004 06:43 AM |
| 3.Slow: Who's Headgasket Has Blown Twice? | AgRunner06 | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 11-19-2003 05:20 PM |
